Throttle spring replacement
seatbelt warning chimes
Help my brother build a 2001.5!!
OK next question for our panel of experts. My trucks bucks sometimes at around 45 mph while accelerating and pulling the 5th wheel RV. The cable looks fine and I think it is the newer style with the plastic sheve to prevent frayiing. The pedal doesn't feel as stiff as it used to so I am thinking time for a replacement spring.
Are there different ones that are stronger? And is a real pain to change them out?
Thanks again, Roger
'98 12V 3500 Dually Std Cab, Auto, 3. 54, Banks Stinger Plus, Sun Coast TC. BD valve body, BD Pressureloc
Roger,
It may not be your throttle spring. Check to see if the "kick down" cable and the spring on the transmission lever is ok.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
[This message has been edited by Joe G. (edited 08-20-2000). ]
The last spring set I got had the ends covered with plastic. Maybe they will wear longer? The are easy to change.
Paul A. Schmidt
95, 4X4, SLT 2500, 5 spd. , 4. 10, 270 hp. ,675ft. lb. TST, AFC spring kit,215hp. injectors, Pacbrake, Walker muffler,
GearVendor O. D. , CenterForce Dual Friction clutch.
Eastern PA.
Yep, & mine only did it towing the 5'er & up-hill. There is a linkage kit that Dodge will change under warranty. I don't have the receipt in front of me, but they have it. Fixed, end of story. #ad
The only down side is the mucho stronger pedal effort. I'll just bet that if you remove the single spring on the linkage, measure it & get a stiffer one from your local Pep-Boys, same length, it'll fix it. It's a wimpy spring. Go out & manually do the linkage. It's way too easy.
Money Sink - 96, 5 speed, Injectors, 280/685 & AFC housing slid.
4" CAT back & CATless, 4" chrome turn down straight out back.
ISSPRO Pillar, Delvac 1 & Amsiol, K&N, Monicas silencer ring removed, Exhaust brake, Mag-Hytec, 3:54, 235s.
HX35s days are numbered, HX40-16 is here.
Un-Bombed = Boring
[This message has been edited by Forrest (edited 08-20-2000). ]
I found a spring hanging on mine. Unhooked the good end and took it down to the local parts house and bought one that was slighly shorter and it was a cut to fit. Bent it where it needed and cut the excess off. Works great sofar. #ad
Mac
95 Ram 2500 Auto Std Cab, Cat & Muffler Fell off, 125,000 miles.
Bombed-to-be!
Roger, mine did that about half way thru 3rd gear. DC fixed it in warranty - tsb 18-29-97. After the tech finished,we went for a ride and it was cured. He said the fix included different bellcranks and springs. Craig
97 3/4Ton, 2WD, 5SP, #11 Plate, 14 Housing, AF942M Air filter, Gutted Cat, 4"From Turbo, Airlift, Shortened Frame, Custom Bed, HEY FORDBOY POWERSTROKE THIS!
