I have a 2001 Ram 5. 9L Cummins with an automatic transmission. The truck has 66,000 miles on it. The only mods on the truck are a BHAF and a Banks 4" Monster Exhaust with the power elbow. I just recently had to change the VP44 injection pump, as well as, the lift pump. I also installed a low fuel pressure light at the time of the VP44 pump install. The truck ran great for about a week. The issue I am having now is when I put the pedal down, in any gear, the truck will take off, but as it gets into the higher RPM range, it seems to flatten out. You can pretty much hear the turbo stop working. When I say that, you can hear the turbo whistling up until the point where the power loss occurs and then it sounds as if the turbo is silent. If you feather the pedal you can hear the turbo again and then it seems to have its power back. While this is happening my low fuel pressure light never comes on. The truck is throwing two codes P 1693 and P 0234. I have looked up the codes and it seems to be pointing to the wastegate in the turbo. Could that be responsible for the power loss? I have already put two turbos on the truck while it was under warranty, which it is no longer. Is there any way to get the wastegate unfrozen, if that is what it is, or do I have to put another turbo in to fix this issue. I have seen some posts where they talk about replacing just the wastegate valve, but I don't think that is an option for this particular model/year. I believe the newer ones are external to the turbo, where my model is internal. Any ideas would be greatly appreciated. I’m not really up to spending $1500 on a turbo just weeks after spending big bucks on the VP44 pump.
