For fixing the death wobble problem, I am replacing the tie rod ends with Moog greaseable parts.
The original tie rod ends have been on for 7 years. After soaking the parts with Kroil, I have a rather large 2 leg puller on the joint but it is not moving. Hitting the puller shaft end periodically with a hammer while the puller is on has not worked either.
Would applying heat to the bracket the tie rod goes through be the next step?
Other ideas?
Other ideas?
