I was under the truck today (1997 2500 4x4 Diesel) and notice I have one tie rod end that has a lot of play so it, and probably the other 3 will need to be replaced. In doing some research it seems like maybe the Luke's Link kits might be the answer. I'd appreciate any input from those that have used LL. I will not be doing the track bar since it's a Moog with a lifetime warranty. I'll be replacing it with another Moog.
Some questions:
How hard is the install? It looks fairly straight forward to me and I have all the tools.
The grinding concerns me. How easy is it to screw up by grinding too much?
Will I have problems with clearance on the steering box or differential or is that just if you use the LL on the track bar?
Will I need a front end alignment afterwards?
Was there an installation article in TDR? I have all copies since 1997.
Anything I'm missing?
Thanks!
Some questions:
Thanks!
