I suspect I have a wire, or wires, failing from the bending caused by the tilt wheel. In order to get my low beam lights to work I have to get the steering column tilted just right. The high beams work fine.
I suspect I will have to use the wiring diagram to identify the low beam wire and replace as needed.
Has anyone been down this path before? Is there a weak point in the wiring configuration; anything I should know? Any helpful hints?
Thank you.
Thank you.
