Timing a 1992 Dodge W250
My1992 Dodge W350 Duallie...
Reunel Rear Tow Bumper
I have purchased a YA8331 Snap On timing tool. Any good place to find out how to use this correctly? I need to know how far to set the timing forward for maximum power. My exchanged injection pump didn't have a mark on it so I have no guideline. Purchased the timing tool to rule out a bad injection rebuild. Thanks
Roy in Phoenix
How far depends on how the pump and injectors and none react exactly the same to pump timing. For example, my pump was turned up and had stock injectors and performed better at 1. 45 mm of lift than 1. 65 mm.
As for using the tool,
1. Locate top dead center. The timing pin is sometimes not exact and knowing the timing pin is correctly engaged all the way can be confusing as well. The FSM has a valve dropping procedure to locate TDC and this is the procedure I used to verify the timing pin was accurate. Then I fixed a pointer to the timing case cover and marked the damper pulley to make identification easier.
2. Insert the YA8331 and set it to 2-3 mm of preload at TDC.
3. Turn the engine backward until the dial indicator stops changing. Set preload to 2 mm.
4. Turn engine to TDC and read the dial indicator. The difference between the preload and the reading is the pump timing in terms of mm of lift.
5. Rotate pump toward cylinder head to advance timing (increase dial indicator reading) or backward (away from cylinder head) to retard timing.
Repeat as necessary. Note that the dial indicator readings will change significantly with very small movements of the pump. The pump should be securely in place when taking the readings - fasten the 3 nuts so they are snug.
Brian
I just thought of something else. When using the Snap On YA8331 or similar tool, and all the injector lines are installed, one needs to remove only the #1 injector line to use the tool. The procedure is not that bad.
Brian
