Alright, I know my timing is in pitiful condition, the white smoke is driving me freakin crazy. MY question is where is the cheapest place to buy the kit so I can set it? Or someone out there might be kind enough to let me borrow thiers
But I doubt anyone would do that, and I don't blame you. Also, I can set the engine at TDC, no problem, but what do you have to do after that, pull the gear off the front of the pump, set the dial indicator on the pump, then do you turn the pump and set it while the gear is off?? I've never messed with timing on a setup like this, only on the big 855 cummins with the cam followers. Wish I could just add or remove gaskets, that would be great. Any reply would be greatly appreciated.
Thanks,
Willie
Thanks,
Willie
