I cannot advise you on the Phoenix Friction clutches. I repleaced mine with the South Bend 1947-okhd. I will say that the transmission jack you use is going to make the job alot easier. I used a very large trans jack, that is adjustable in 3 different directions. I placed 4 inch blocks under the front wheels to allow enough room for the shift tower to clear the floor. I also placed a floor jack under the front of the engine to keep the front of the engine from tilting forward. Use loooooong extensions and you can set under the truck at the rear of the transmission and remove the bolts once you have your jack supporting the transmission weight. This worked well for me, just my $.02 .
