Here goes. The tach (factory) in the truck is going dead, then it comes back to life. Kind of acts like a stock lift pump going bad. Just comes and goes.
If it does it going down the interstate (65-75mph) you dont notice a difference in engine performance. . doesn't mean its not affecting the engine, but if it is I cant feel it. The check engine light comes on as well.
If it starts doing it at idle or a slow crawl (5-15mph) the engine starts getting erratic on its idle... sounds like a mean pulling truck with that "chukka chukka chukka" sound. The check engine light comes on this way to.
I never noticed this until I put all the transmission stuff in, so all you Bill K scholars let me know what that orange wire does I cut a couple months ago
Does anyone know if that orange wire from the PCM/ECM/ECU on the firewall that Bill K has you cut and put a diode in it for the valvebody/torque converter swap is related in anyway shape or form to this? Could that diode be poorly connected causing this? Could the diode be bad? Am I on the right trail with this, or should I be looking else where?
I at first thought it was the tach drive sensor going bad, BUT if it was that, one would think only the tach would go bad and engine performance wouldn't be affected.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, EZ box, race transmission, Barry Grant fuel system, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member
My Diesel Page
NRA Life Member
My Diesel Page
