Tires Again
Lock Out Hubs?
Need Old School Alignment Shop in Atlanta, GA
On a 07 mega cab 4/4 how tall and what size tire can I go to. trying to get 35" tall and the same whith I am running now. I have 4. 10 rear ends and wont to drop gear to about 3. 90 or there about. I do not wont to lifth the truck, I would have to pack a lader and sky hock.
Thanks
Harlan:-laf
To fit 35s without rubbing you have to do at least a level kit. 35X1250x17 will fit on stock rims or rims with 5" or more BS.
if you get the bigger tires, the 4. 10s will be fine. changing them to 3. 9 won't make that big of a difference on anything other than your pocketbook.
Thanks for the come back. Every little bit helps. Just went down town ,Fernley and the Shell was 4. 499, cant even type the number it hurts so bad.
Thanks
Harlan:-laf
