2nd Gen Non-Engine/Transmission "To do" list while the box is off the truck?
2nd Gen Non-Engine/Transmission socket size for axel nut
Engine/Transmission (1998.5 - 2002) OverSize Injection Lines
I'm removing the box off my 96 to go after some long term problems. I would like to be efficient in this labor and fix everything that is made easier with the bed off and while access is enhanced.
> I had a rear brake line rust through last fall and there is a replacement line (I view as temporary) up over the tank right now with the old rusty one still there doing nothing.
>>> So I want to replace every inch of crappy tin brake & fuel line with stainless steel and/or marine hose. Nothing has ever been touched in my fuel system except to change the fuel filter. The truck is 15 years old, lives in the rust belt, and with one brake line already rusted out, all the metal brake & fuel lines are now suspect and untrustworthy.
> My fuel sender has not worked right for a couple of years.
>>> I want to fix it as permanently as possible without spending large.
> My rear brakes need replaced as do the corroded parking brake cables.
>>> I have new drums and new cables and will be upgrading to the Chevy wheel cylinders. I still need to choose rear brake shoes. . ? Hammer once advised using very cheap & soft rear shoes when upgrading to the more powerful chevy wheel cylinders. That seems contrary to using "the best I can afford" but Hammer usually knows his stuff. Any other opinions?
I will also be completing my plastic underbody shielding under the bed before I reinstall it. But what else should be done, checked out, replaced, upgraded, etc while the box is removed? What else should I have on hand and ready and where do I find the best deal on it?
I can't believe only EGR brakes offers stainless steel hardlines for our trucks, but that's all I can find.
BTW: I'm replacing the hard brakelines with the intention of also converting to hydroboost. This will likely affect whether I order a stainless kit for a 96, which is my truck, or a 98, which had hydroboost. Am I correct? The soon-to-be-installed Ford dual-piston calipers will make the front plumbing even more interesting, but there I believe I need to take one step at a time.
Oh, and I hope to repaint the truck sometime in the next year. I don't care for the maroon over silver-gray and want to go with either pewter or charcoal. Can I paint the front of the box and the rear of the cab now while I have them separated? Or will I end up with a very noticeable paint line on the cab when the rest is painted later?
I did the rear brake rebuild/wheel cylinder upgrade routine earlier this year and chose to run the cheap/soft compound shoes as you mentioned. On first install, they were a bit grabby running empty, but have bedded in nicely and definitely are an upgrade over the stock configuration. When towing/loaded the additional stopping power is welcomed.
During wet conditions/sudden stops or dry condition pannick stops its possible to get the rear brakes locked, even some brake hop, which I never could get to happen before. I still find it beneficial to keep on top of the adjustment.
For the money spent ($12 a side?) its a great bang for the buck upgrade. The money saved on running the cheap shoe, versus the ultra ceramic/carbon fiber/kevlar/space shuttle rear shoe more than pays for the wheel cylinder upgrade.
On the other items it sounds like have hit all the high spots: fuel sender, brake/fuel lines, parking brake cables.
If you have the ability to bend/flare your own lines take a look into cunifer line. Its a copper/nickel alloy for brake and fuel lines. Easier to work with and flare than stainless, just as weather resistant (copper/nickel/steel). I plumbed my 70 Nova with the stuff after fits of frustration with steel/stainless steel. Very easy to bend, form and flare.
http://www.brakequip.com/pdf/ezibend_tube_booklet.pdf
FedHill Brake Line - Where to buy brake line, fuel line, brake line flaring tools, brake line nuts and brake line fittings
Chris
