Kirwin
My truck was 5 years old 8/12/2018. I recently started getting the dreaded check engine light with code P2201 ”NOx sensor circuit range/performance bank 1 sensor 1”. I knew that the T05 recall was supposed to be the answer for this issue so after clearing it 4 times in 6 trips I made an appointment with the local Ram dealer where I’m currently working in Saratoga Springs NY to get T05 and BTSI flash completed. My truck has been stored in a heated air conditioned garage in Virginia (so corrosion is not an issue) until 6/1/2018 when it’s not pulling my RV. I’ve had 3 or so other check engine lights that came in and cleared by themselves in my 5 years of ownership that I did not investigate as they cleared relatively quickly by themselves. I bought the truck as soon as it was unloaded at the dealer in August 2013. The dealer performed the T05 recall and I picked the truck up Tuesday after work. 21 miles later the check engine light comes back on and the code is the same P2201. So I call the dealer and they can get it back in Friday. I drop it off and discuss my issue with the same mechanic who performed the recall. 2 hours later they call me and say that I need a new NOx sensor which lists for $1400 and it is not covered by the emissions warranty. Holy crap! Really!!! Less than 2 months out of warranty! So I tell them that I have an aftermarket extended warranty and let’s get approval for the repair. They called back and said that the warranty company wants to use a non OEM part that costs just shy of $700, and they will cover the part and labor for replacement. They also offered to pay that amount toward the OEM part if I go that route. After me and the service manager had discussed my options, the service manager suggested that I may want to call Customer Care and open a case to see if they might, as a good will gesture, cover some or all of the repair cost. I did that and I’m waiting on their answer. So I’m looking for advice. My fear is that this won’t fix the problem and I’ll have a new $1400 NOx sensor that I didn’t need that I can’t return. I discussed this with the dealer and made it clear that if this doesn’t fix it, that part is on them. If I go with the extended warranty aftermarket part I worry that if the problem recurrs now, or sometime down the road, Ram will say it’s because of the aftermarket part and won’t work on it until I put in an OEM part. The truck has been trouble free up to this point. What would you do?
