Topzide
'Service Rear Park Sensors '
Probably some wiring too..
Are you domiciled in the Rust belt?
It was the driveline both times. The compound joint on the transfer case side. The one with the super small grease fitting. Both times the truck was in 4 hi. Both times there was a some snow on the ground...maybe 6-8" the first failure and no more than 4" the second time. Both times were at very low speeds/ throttle. Maybe 5 MPH. The first time I was rounding a corner and the driveline gave up with a loud bang. I believe this to be related to a defective/low quality component. The second time I was simply pulling out of my driveway. I believe this to be improper installation of the first driveline by the dealer. It could have also been a defective part again, as it ~6 weeks until they could get a replacement. So there could have been a whole batch of junk parts.Can I ask what was the cause of your repeated front driveline failures? Drive shaft or axle?
