Tongue Weight Revisited
Looking for TT to Rent for Mem Day in VA
Need race car picked up.
BrianWalker
My brother wants a new Gearbox toy hauler, 26' front sleeper.
Dry wt. = 6464#, Dry hitch wt. = 1174#. (from brochure)
This is 18% of trailer wt.
Rule is 10-15% from what I've seen.
Say he loads it to its max capacity of 11,400# and in a perfect world, it's perfectly balanced.
Does this mean his TW is now 18% of 11,400# or 2,052#, right?
No hitch is rated this high.
But if you add Weight Distribution, from what I've seen in posts, approx 80% is transferred to the truck, 1640#.
This leaves 410#, of which 10-20% is transferred to the trailer.
400# is not heavy at all for a 3500 with a class 4.
The problem I'm still having is that the hitch/reciever, ball/WD system is still controlling 2,052#.
The biggest Putnam is rated for 14,000#/1400#.
Am I nuts? Is the Putnam or anything else not enough?
Brian
You would have to load it tail heavy to keep the hitch weight reasonable, which I assume is typical with a toy box since the cargo goes in the back anyway.
Not only will gross weight vary when you vary the load package, the tongue weight will vary depending on where the load is positioned.
Think of the trailer as a balance beam with the tires as the fulcrum. Just because there's more weight in the trailer doesn't have to translate into a higher tongue weight; it could be less.
I don't know how accurate those brochure figures are (may vary depending on options), but there is only one real accurate way to measure weights, and thats to take it/them to the scales and weigh them - loaded and unloaded.
I've read in a post on one of the RV threads that even a 1000# loaded in the rear only changed the tongue wt 150#. I don't know how accurate this is. Even if its 20% off, not much change for what is loaded.
I will have to buy the tongue scale now, just so I know what MY weight is. I hope it's not over my hitch/receiver rating.
Class IV = 500/5000 lbs w/o weight distributing bars. Class IV with weight distributing bars = 1000/10,000. If you're over these weights you (or your brother) SHOULD consider one of the many higher rated Class V hitches that are out there (Reese Titan, Torklift Superhitch, etc. etc. ) Always weigh your tongue. FWIW you don't need a tongue scale, just weigh your trucks rear axle empty and then with a trailer and subtract your two numbers. Close enough.
Good luck
Dave
Oh, I forgot. As many have alluded to, the dry hitch weight at 18% (1174) lbs doesn't mean the hitch weight for the fully loaded trailer would be 18%. BUT if the dry hitch weight is over 1,000 lbs you should consider a different hitch anyway IMO.
Dave
I did the rear axle with trailer. But I think I had the front wheels to close to the scale. Which may have placed more front weight on the rear.
I guesstimate my TW to be closer to 1,000#, than the 850# as specified in the book.
This was with the trailer basicly empty, no water, clothes, food, toys, etc... Now it makes me nervous to find out what it is full.
I will be buying a tongue weight scale.
I ask all this wanting to help my bro make the right purchase and help him understand the numbers juggle and clarify more for me. This is his first truck/trailer purchase.
Thanks.
I have a 28' Desert Fox Toyhauler TT
empty weight was 6800 and dry TW is 1200# so you are about right on the one your brother wants.
I have a 500 polaris that goes in the back and it helps the TW some, my water tanks are right about at the axles so it is ballanced, I would estimate my TW loaded is about 1400#
I bought a class 5 hitch and it has 1400# and 14000# rating so I believe I am good on that. As a saftey thing, I bought the Hensley Arrow hitch to eliminate the fishtailing. I am at 20,000# GCVWR with my polaris and full water and 2 other pople... .
