On paper fill time would be linear, in reality it is not. The more engine rpm the less time the port is open so the actual volume filled decreases. As you turn the pump up the differential between actual and theoretical get farther apart.
Fuel temp does have an effect on SOI given all other parameters stay the same. Heavier fuel is harder to push and takes more time to move if nothing else is changed then SOI moves.
This is why the VE has dynamic to compensate for all the variables, fuel temp, intake air temp, etc. Thats a lot different than the P pump that has no dynamic timing advance.
This is where case pressure comes into play. The vane pump is generating the pressure to drive the dynamic timing curves plus influencing how the fill rates adhere to design parameters. If that varies for whatever reason your timing is bouncing.
Like you pointed out, advancing the timing puts more power into the engine and creates more efficiency. The down side its it robs boost becuase of the lack expansion in the exhaust. On a large turbine turbo this can be significant and contributes to lost efficiency at a certain point because the trubo cannot supply the air.
At a specific rpm where the IP is capable of deliverying the fuel and the turbo is capable of providing the air, timing should be able to be claculated for optimal use. Need to figure out what the dynamic timing curve of a VE is, how to measure it, then how to influence it and there is another tool to play with. An initial set of timing is one thing, the actual timing curve in crank degrees is another whole animal.
That is another difference from the p-pump, the VE uses less initial timing because it has a dynamic curve. A lot of times 15 degrees or the represenative pump position thereof, is too much. Other times its not enough, depending on pump, injectors and build.
Outside of the specific CPL's, there is not a lot of solid data on just what happens to timing, duration, etc, and what is the best setting. Trial and error then test.
ok this might be kind of choppy but i wanna take each of your paragraphs one at a time.
i understand fill time will change with rpm, as the engine speeds up
the amount of time the fill port is open decreases. would that not be inversly proprtionate to rpm and therefore linear? also increased fuel of the pump meaning more fuel injected every event would change fill time. that makes sense, wouldn't timing for a specific rpm eliminate that? even the new electronics cant run at optimum throughout the entire engine rpm. if they could the torque curves would be flat.
i still disagree with fuel temp affects timing, even engine oil if compared at the same temp would build pressure at the same rate. im pretty sure any fluid would since they are not compressable the viscosity or density would not affect the pressure build rate. to come back to a more relisitic thought, these engines are built to be tested in a cell where all outside variables are corrected. humidity, ambient temp, fuel temp, all the conditions for testing to sae standards, they have to test every engine to make sure it meets advertised horsepower +- 3%. i think the standard is 70*f for fuel temp. now the viscosity of the fuel doesnt significantly change from cloud point through about 200 degrees. i dont think fuel temps are gonna be higher than that in normal operations. if they were you would really notice a power problem. im not convinced yet that temp would affect soi. your explanation makes me think of being between a rock and a hard place. the engine is running and has a 2:1 gear reduction to the pump, there is even more mechanical advantage provided by the diamiter of the gear compared to the plungers. the pump and engine would never notice the extra density, if it did the engine would slow and timing would stay the same anyways since the engine is not advancing as fast. what your describing sounds like parts are about to be broken. something has to give in that situation the pump wont and the fuel wont so things are gonna happen on time.
dynamic timing is not used to absorbe all the variables. it cant, dynamic timing is determined off of rpm. its purpose is exactly the same as why spark ignition is dynamicaly advanced. the fuel needs x amount of time at y engine speed to burn properly and create power. gas engines suffer much more from lack of advance then diesels do, thats why not all diesels have dynamic timing. the new scroll fuel system from cat is virtually identical to the p7100, just a supped up version of it. cat designed a timingadvance unit for its 3406b models. i know there where 2 types one was spring/hydraulic the other was hydraulic/ hydraulic. the timing advance unit allows for a wider power band, more horsepower, it also helped meet the 1986 noise emmissions as well.
case pressure. is it building that pressure in the pump body? equal pressure all over? i can see a timing advance working of fuel pressure but it doesnt seem very effective where and how much pressure is it building. if pressure is building from the vane pump around the fill port as rpm increases, timing advances, and pressure increases wouldnt fill times stay very close to steady? less open time but more force pushing it in at a higher velocity.
on the turbo issue you mentioned, addmittedly this is a gray area for me (still some black majic in the turbo) my understanding is similar to what you describe, only i thought it was more the change in temp across the housing, inlet --- outlet that drove the turbo. i do know that in the high hp pullers they like to lengthen the duration injecting some fuel too late for power but it burns in the manifold and generates more heat driveing the turbo. its the same principle either way i think. in this application though i dont think its a concern, especially since eric is talking 300 horse thats easy to size a turbo for with the advanced timing. like i said it a gray area and probaly something to be concerned about when designing an entire engine or even just trying to heavily modify an existing one to meet many different goals at the same time, I. E. big power and good fuel mileage.
on the last part comparing a ve to a p pump, i would agree with you but it looks like from what eric said earlier static timing is 12. 5 degrees the early p pumps used that setting as well. ve's just have dynamic which is probably why they tend to get better fuel mileage.
as for measuring dynamic timing and all of that, i actually have the info in my books for cats engines, obviously cats tools and what not, but the same could probably be set up and calibrated for any engine, this would allow you to measure it very acurately. then chart it, figure out your other math and you'll have it.
Not saying they don't have them, saying they verge on impossible to find or get.
Just getting a pump shop to do anything other than run the basic tests at an idle is problematic. They are telling me there really is no spec for, say, 2000 rpms and good way to measure pressure and timing. The official party line is set to specs and it should work.
We know about what the total is for dynamic timing, 21 degrees (I think that is crank degreess but again... . ) but no real good idea what the rom curve is or pressure curve applied to it. The timing is dynamic based on case pressure which is tied to rpm but what is the link?
I don't have a map that says at 2000 rpm case pressure is 210 psi and\or timing advance is 13 degrees at 210 psi. Even this, where does the dynamic come into play. 1100 rpms? 1500 rpms? What is the pressure for the curve? 180 psi thru 260 psi?
Timing curves, pressure curves, fill rates, cam profile, etc, simply is tough to find from Cummins. Sooo, we guess and hope. :-laf
i agree 21 degrees is in relation to the crank, but i think that is total degrees static+dynamic+port effect. all of my books and lectures talked about timing in degrees of crank rotation, all the literature ive ever read goes with that too. is it possible to measure case pressure? im sure timing is directly proportional to case pressure. not 1 psi = 1 degree but if we can get maximum case pressure and maximum degrees of advance possible you can get the needed ratio. then measure case pressure and it would tell you where the advance is at. if you have all that info you will know when start of advance happens and where end of advance happens. you could then map it, time it, measure it veryaccurately.
if 21 degrees is total advance and 12. 5 is static that is 8. 5 degrees dynamic timing. port effect is . 1* per 100 rpm starting at 0. so port effect for 3000rpm is 3* subrtact that from dynamic the pump can advance 5. 5 degrees of crank angle or half a tooth. this sounds about right to me. the p pumps like to run about 15* static, most any of our engines like it around 2000 rpm. so a p pump is running 16-17 degrees at 2k rpm. a ve is running at 2k 12. 5 static + 2 pe + 3. 5 to 4 degrees for dynamic thats about 18 18. 5* id be willing to bet if we figured the rest out, or if someone managed to get the info from bosch or cummins, thats where these engines run. 18 is a lot of timing, but the first gens are known for good fuel mileage, think timing could be doing it.
