1. Would someone please chime in regarding the validity of this claim?
2. Is the spacer really superior (to twisting the pump)?
3. Does the M&H spacer result in too much advance for a bone stock truck?
Twisting the pump results in advancing timing across the board by a set amount (for example, timing is 3° advanced at every point throughout the engine load/speed range). The M&H spacer only adds to the range of dynamic timing, accomplished by the KSB. In other words, the base timing at idle, low speed/load stays the same. As the engine ramps up in speed/load, the amount of timing advance that the KSB can give is increased by the M&H spacer. This is probably more important if you also increase the available speed/load the engine can put out (such as 3200 rpm spring, etc). This could be advantangeous, because advancing the base timing too much will have a detrimental effect on low end torque and/or turbo lag time.
Do you mean the physical hydraulic delay in causing the injector to pop-off?
I know that SOI isn't the "tell all", but it is a (somewhat) useful thing for me to roll around in my head and reference. I see you have a 3rd gen like myself, and are aware that rail pressure, injector size, etc, etc all have an effect on what the "timing" actually is.
I guess my confusion, is trying to reconcile what I do at work, with what I do at play. At work, our engines are highly instrumented, with in-cylinder pressure transducers, high speed data acquisition (one fifth of a degree CA resolution), with complicated and very expensive real-time combustion feedback (heat release plots, pressure traces, 10% mass fraction burned, 50% MFB, 90% MFB, IMEP, BMEP, NMEP, peak pressure, pressure rise rates, etc). The data is at such high resolution and transfer rate, that even with a large buffer, it is nearly impossible to save the data to the outer portion of the hardrive's circumference, as the data can't be written that fast. And then, I jump in my truck to head home, and pick 0, 1, 2, or 3 for timing on Smarty, and have no idea what any of them do, how aggressive Marco went on his "advanced" timing settings, etc, etc. Or I jump in the '91. 5, and wonder how much bsfc improvement I could get by advancing timing, but struggle with the apprehension of sacrificing longevity due to raising peak cylinder pressure too high.
This is probably not productive to talk about such things, but I've been somewhat soft and wordy and rambling today for some reason. Which brings me to say, I think I'm going to sell my Smarty, TST, and TS MP-8 and get EFI Live for the '06. I still won't have a clue what is going on in the cylinder, but at least timing will be what I tell it to be... or something like that
--Eric
Thanks Eric, that's helpful. Sorry to be a noodge, but I now have more questions.
I have no plans to turn up my pump fuelwise, but I do tow periodically and would like to tow at highway speeds with OverDrive turned off. SO, I have bought the "366" governor spring (3200 rpm) from the local Bosch shop and plan to get it installed without making other adjustments to the pump.
Based on what you said, the M&H spacer would have essentially no effect on my truck at idle. With the background I described above, would the M&H spacer give me too much timing advance at highways speeds while towing (bone stock)?
enafziger, im wondering if you might be able to help me out.
I'd be glad to, but you may have to be patient.
i can be paitent, i have many other things going on as well and can come back to this when you have the data for me. whenever its conveinent for you is fine.
I have a few plots I think I can share, but I can't figure out how to get them to show up here... copying pasting doesn't work. I can't think of anything right now other than trying to make a jpeg image out of the plots, uploading to a photo imaging site, and then posting here as a picture... which I can do, but I don't have time for right now.
Garrett's site has some good basic info on it, particularly on turbo charging/engine efficiency. Some general diesel stuff at: TurboByGarrett.com - Turbo Tech101
And here, for volumetric efficiency stuff... TurboTech 103 Expert really has the most useful info, particularly toward the bottom of the page. TurboByGarrett.com - Tech Center
i will read into these and see what i garner out of them and apply it to my work.
Some common numbers that come to mind for a DI compression ignition engine are: cylinder pressure at start of injection ~ 400 psi, maximum allowable cylinder pressure for sustained load ~ 160 bar or 2,300 psi, peak pressure rise rate 10 bar/CA degree, maximum piston speed 12 m/s, etc.
400psi thats at full load? based on compression ratio, boost pressure, and ambeint air pressure? the pressure rise rate, thats max allowable/best case? is there a rule of thumb rate? or a formula that could factor in fuel volume, cylinder pressure, temps, etc. to determine the rate of expansion/heat release, for a given set or paramater i. e. half load, low rpm, cruising, etc. piston speed, 12 meters? per second also is that average max speed or peak max speed?
also is there a ratio for the expansion, like that for black powder? say an oz. of fuel will expand to a certain amount, and at a rate in time?
The concept of flame propagation speed doesn't really apply to diesel combustion. In the SI (spark ignition) world, it's useful because you can often assume that the "flame" will start at the spark plug and propagate out (although sometimes the exhaust valve can be hot enough to ignite the fuel/air mixture slightly before the spark). In diesel combustion, the mixture is always lean, and mostly very lean. Since the combustion mode is via compression ignition, you end up with lots of localized ignition spots within the cylinder that start the combustion process. These spots are dependant upon so many things that it's hard to do much without advanced combustion modeling software. So, the diesel equivalent, so to speak, to the SI flame propagation speed, is Mass Fraction Burned, or MFB. We use DCat some from Drivven for real-time heat release and combustion feedback. There are others as well, AVL etc, but mostly they will indicate 10%, 50%, and 90% MFB. Some people use 5% as the start of combustion indicator, and some 1% (although that's so noisy that results are not consistant). Thus, I suppose you could compare CA degrees between MFB10 and MFB90 as "burn time". There are so many things that affect burn time, that it can vary drastically... fuel properties, engine design, piston design, injection pressure, cam design, egr rate, swirl and tumble, etc, etc. As a general rule of thumb, injection timing needs to be advanced 8 - 10° for low cetane fuels to have the same combustion phasing (MFB50) as a high cetane fuel (low cetane meaning 40 and high meaning 55 or so).
the reason i asked about flame propogation is i came across a company that is doing work on the physical properties of fuel using an additive, from what i garnished the additive has an affect on flame propagation, heres the link Fuel Additives: Fuel Treatment - Viscon if you have time i would be interested to hear your feed back on this, i rarely buy into a companies advertising.
There are so many variables in the operation of an engine, that even with advanced simulation, it is difficult to predict things... and with everything, there is a limit of what is "good". For example, for optimum bsfc (brake specific fuel consumption), you would ideally want all heat release to occur instantaneously right after TDC; however, this is not achievable do to chemical kinetics and physical nature of things... but even if it were possible, allowable peak pressure rise rate (~10 bar/° as stated above) would cause you to have to spread out the burn. The 10 bar/° number has to do with head gasket integrity, connecting rod strength, rod bearings, etc.
Moreover, it is generally assumed that better atomization, resulting from higher injection pressure, increases combustion efficiency. This is generally true. However, you will find a point that the parasitic loss of pumping the fuel to higher pressures is greater than the increase in efficiency from better atomization... and as such, bsfc is actually lower.
--Eric
Wow... well, I'm definately not the best one to be giving a course on engine and combustion, but I'll answer as I have time.
Full load is somewhat subjective, primarily to the constraints I gave earlier. The 400 psi cylinder pressure I referenced is simply a rough value for the pressure in the cylinder at combustion TDC at the time fuel is injected... regardless of speed/load. The 160 bar or ~2300 psi value I gave is a generally accepted upper limit of allowable maximum cylinder pressure for a typical light duty modern diesel engine. Yes, 12 meters/sec is generally accepted maximum piston velocity. Obviously you can push this limit farther, but at the detriment of longevity. OEMs are rarely interested in pushing things to the ragged edge for model year release because they warranty parts. For the research world, the OEMs push things to failure.
When an OEM publishes "full load", there is usually a rated torque and a rated horsepower, obviously occuring at two different engine speeds. When we are running an engine for research purposes, there is no such thing as maximum load; rather, you always are limited by a known boundary condition of probably engine failure... for example, the maximum pressure rise rate, cylinder peak pressure, exhaust temperature, piston velocity, etc. Within those boundaries, you can change things however you would like.
Most of the work going on now isn't just inject fuel and burn it... it has to do with different combustion strategies such as PCCI, RCCI, HCCI, etc, etc, where combustion is pre-mixed charged, reactivity controlled, homogeneously charged, etc. Variable compression ratio, camless engines, dual-fuel (gasoline/diesel) engines, novel 6 stroke cycles, waste heat recovery, turbo compounding, "super" turbos, emulsifications, etc are being looked at. The trend is toward smaller displacement, more highly turbocharged engines.
There is no good formula for friction. It is much better measured than calculated. With a motoring dyno, you get the engine up to temperature and kill fueling. There are other ways to do it if you don't have a motoring dyno, but it's not a paper and pencil exercise.
By definition,
fmep = imep - bmep
or friction mean effective pressure is the difference between indicated mean effective pressure and brake mean effective pressure. Indicated work is the area enclosed on a p-V diagram from an engine and represents the work done by the gas on the piston. This indicated work per unit swept volume is imep.
The negative work that occurs during the intake and exhaust strokes is termed pumping loss, and per unit swept volume, is termed pmep.
There is sometimes confusion with the term imep, such that some people include pumping work in imep and some don't. To be more clear, gross imep = net imep + pmep.
The work output of an engine as measured by a brake or dynomometer is termed bmep, or p sub b (pb). Brake power = (pb)(piston stroke)(piston area)(number of mechanical cycles of operation per second)
Mechanical efficiency is defined as bmep/imep.
--Eric
anyways, 400 psi cyl. pressure is the pressure @tdc compression just prior to fuel being injected correct? so that is a mean pressure factoring in all loads, across all diesels engines? i ask because the cylinder pressure is going to change a lot with load. as i know it, and i could be wrong, cylinder pressure = comp. ratio(atomosphieric air pressure + boost pressure), that would change a lot with changes in load.
my last question for the moment is with the friction information, the way you said its measured, does that seem really acurate? wouldnt the compression affect the measurement, or did i just miss something in your explanation? i will have to read over a few more times before i will really start to get it.
Almost right, but calculating cylinder pressure is a little trickier than that. Fluids heat up as they are compressed, and as such, the temperature rise causes an associated pressure rise... for an ideal gas, I think the pressure rise due to temperature could be related by:
PV = nRT
or solving for pressure, P = nRT / V
where P is absolute pressure, n is number of moles of the fluid, R is the gas constant, T is temperature, and V is volume. The main thing here is that temperature and pressure are directly proportional, such that doubling the temperature will double the pressure (assuming the fluid stays the same, the amount of fluid is constant, and the volume doesn't change).
Nonetheless, by using the specific heat ratio of the working fluid, you can account for the pressure rise due to temperature. (Specific heat ratio is designated by lowercase "gamma", but I don't know how to make that symbol here. ) Thus, the formula becomes:
Pcylinder = Po x CR^gamma
The specific heat ratio for air is 1. 4, such that the formula becomes:
Pcylinder = Po x CR^1. 4
Po is cylinder pressure at bottom dead center
CR is compression ratio
So, for an example, if Po is atmospheric pressure of 1 bar, and compression ratio is 10, we have:
Pcylinder = 1 bar x 12 ^ 1. 4
= 32. 4 bar
= 470 psi
So, part of the resultant cylinder pressure is from the compression of the air, and part is from expansion of the air due to temperature rise.
At least I think that's what I remember...
--Eric
this is all for static cylinder pressure right? once boost starts then the pressure rises above the 400 mark, without factoring in heat expansion. <!-- google_ad_section_end -->
another question, when im cruising my pyro is right around 600 degrees f, using the formula you gave te is 33% which is about right rule of thumb has always been 1/3 to water 1/3 to exhaust and 1/3 to flywheel. so if i take that 600 and multiply by three thats roughly the average cylinder temp? could it be peak? what do cylinder temps run usually. <!-- google_ad_section_end --> <!-- / message --><!-- sig -->
I'm curious as how your company/department handles engine testing. Is it all on "stands" or do you test in vehicle, too? Do you modify engines/cylinder heads/turbos for instrumentation?
Also, I also see you have flow bench equipment..... ever tested the 5. 9 heads? I'm curious if you've ever noted the specific restricitons... ... <!-- google_ad_section_end --> <!-- / message --><!-- sig -->
