Details here: TDR Privileges
I just bought a 1990 with a 5 speed and what I believe are 4. 10 gears. I have a new speed sensor ordered to fix the speedo but can anyone tell me off hand what the top speed is?
Have you looked at the transmission? The reason I ask is I belive on the 90 model the speedometer was cable driven. There is a sensor but it should only feed the cruise control system if your truck was equipped with it.
An all stock truck, 4. 10 geared, w/5spd, they top out at about 84mph. This is the srw trucks w/235x85R16 tires. The duallys w/215x85R16 tires top out at about 80mph.
check your throtle adj and take a few turns on the high idle screw. . and you should be able to do 85 or better. . Mine will do over 90. . no problem... I have 33" tires at 90 I am turning about 2800 rpm...
I bought a 89 12-11-1988 5 sp 3. 55,s it went 87 mph at 2500 rpm. I have a 90 5 sp 3. 55,s it goes 87 at 2500 rpm . I would think that a 4. 10 would be 75 or so. I think my 3. 55,s did uper60,s in direct.
