SAM Here are some of my answers
Once you're into third and pulling along the converter then locks in, and when you've pulled through the r's then the o/d hits? 3rd locks up at 28mph and shifts to locked up O/d at 57 mph. Both set points were selected by me. The 57 mph is te point where my rpm is over 1800 where the torque is high enough.
Does the converter hit based on the gear, or speed, or both, and can you adjust those functions? Once set up it shifts based upon mph. You can select the speeds by adjusting the smart box.
DTT is building my transmission this Fall and I'm doing the R&D now on how to control it. Get the smart box and you will not regret it. When lowing in bumper to bumper traffic I shift to 2nd gear and the smart box will keep te transmission locked up down to 18 mph. Again my set point.
Ideally I'd like two modes to control the transmission functions- automatic and manual. I'd like the system to default to automatic mode each time the truck is started (similar to how the o/d defaults to 'on'), in which the transmission acts much like yours does as you describe. However, I'd also like to be able to deactivate the controller so I can activate the converter and o/d manually for those times when I may need to (long grades, big weight, etc). If I need more engine braking with my exhaust brake I can turn O/D off and the transmission will lock up in 3rd.
Does your rig automatically disengage the converter when decelerating, and if so at what gear/speed? In 3rd it shifts out of O/D at about 55 mph to locked up 3rd.
Reason I ask, I'm installing an exhaust brake, and I wanted to understand at what speed the brake would become useless if the converter disengages automatically (the old adage of use the gears to slow down and the brakes to stop... I'm guessing around 10-15 mph?)? When in 3rd I get good braking doswn to 28mph when 3rd unlocks. That is all I need with my 10. 4K 5er. If I needed more I could down shift to 2nd and keep lock up to 18 mph.
My rig is a 93 and I'm installing a '98 47RE (among others), and I'll need a compelte control system. As I understand the system I need may be all manual, in which I need to hit the converter 'button' each and every time I drive, including decelerating... and I'm not sure I'll like that after a lot of around-town driving. So, I'm trying to determine how these systems work and how I can tailor them to what I'm after.
My truck is a 2000 and when in automatic with the smart box on and exhaust brake on I just operate the throttle until I'm up to 62 mph when the cruise control is used. It is not a problem for me.
Another question: I see you have 4. 10's - what is your rpm, at 70 mph, with o/d and converter engaged? I'm planning to also use an 89% converter and 4. 10's, so your readings will be right on with what I'll end up with. I do not recall. I do not tow above 62 mph to try to keep the police away. At that rpm towing I'm at about 1950 rpm. I've put 39,000 miles on our 5er at that speed and it suits us just fine. (Retired with no schedule to meet. )
My exhaust brake works well with my smart box to where I only needed to get my disc brakes replaced at about 70,000 miles and the rear brakes are still OK.
