2Farr
ATS did a mod to the valve body to direct line pressure to the torque converter to keep it locked up in manual mode when the switch is activated. If the trans is not up graded it is easy to frag the input shaft. Been there done that. The EB will help in OD and third gear ( or any gear) if the torque converter is locked. You will have to have upgraded exhaust valve springs or you can float the valves. As for all the different line pressures ATS and I am sure BD when they build a trans if you tell them what you want to do they can build to your application. Mine came with a five year and 500K warranty.
