Engine/Transmission (1998.5 - 2002) torque converter(Slipping?)
Engine/Transmission (1998.5 - 2002) 48re in second gen?!?
I recently installed a comp. drag box in front of a stock transmission(auto)w/90k miles on it. In leval 5,at+120hp. I feel the r. p. ms creeping up. Is know the time to find a local trans. shop to instal an a. t. s. converter and valve body?
Any good referrals out there? So cal area.
98. 5 4x4 3500 autometer boost,e. g. t. transmission temp elect. fuel pressure w/snubber and warning chime/light. Edge Comp Drag Box. 5" exh. westin bars,
push bar. Sport package.
With that many miles, you will need a rebuild.
With-out taking it apart. you (no-one) don't know what is slipping. !! It could be the converter clutch, but could be either of the front clutches-forward or direct- and or the od clutches.
Do a search before you spend your money.
best place is Bellflower Transmission, in Bellflower, had my stage 5 done there in Feb, did a great job and they were pro's... . you will love your ATS. .
