Torque Converter & Valve Body Question
update on lift/injector pump problem
Amsoil v. Fleetguard
A while back, I had a transmission lockup problem (Once the transmission locked up, and then unlocked, it would not lock up easily again).
Under warranty, Dodge replaced the Valve Body, along with all the ATF fluid, and, I hope, replaced the filter at the same time -- they said they do whenever they open up the pan.
MY questions now are:
1) My transmission locks up firmly now. But, once locked up on a grade, as I stomp on the fuel pedal, the transmission remains locked in 4th and will often not down shift to a lower gear, thus the engine accellerates slowly by "building steam" -- builds a LOT faster now that I've installed an EZ box.
1a) Is this continual lockup normal?
1b) Is this lockup condition desirable, as I have read on the TDR that many of you have problems of the torque converter not locking or having problems locking.
2) On flat ground (even with my 6000 lb TT and Boston Whaler combo) and light grades, I always have to keep my foot on the brake pedal to keep the truck from IMMEDIATELY launching. I have read that some of you must press the fuel pedal in order to engage torque converter to move the truck.
2a) Is this immediate launching normal with other 4x4 Auto ISBs? ---- I'm thinking about a Bill K. TC/VB, but wondering if my Dodge VB fix was adequate enough to allow me in delaying spending the $2k or so on transmission BOMB.
As always, thanks for feed back guys..... & dolls?
Steve
1999 2500 Quad SLT, 4x4, Auto, SWB, white with Agate leather interior, all options except fog lights. Very happy with the changed 4. 10 gears to 3. 55. 285/75 tires. Towing a '96 21ft Boston Whaler Outrage with 225 hp Johnson and galv. TT. Getting ready to BOMB because the Dodge is a little doggy towing the Whaler and my big Asian butt. Bomb run #1, Edge EZ box. Next???
"LIFE IS TOO SHORT FOR CHEAP BEER/DODGE PARTS"
the TC locked is a good thing , yes it only builds slowly , but if it unlocked you would be creating alot of heat in the trans as the fluid coupling of the stock convertor is not very good .
also yes some creeping is ok , but your STOCK TC is doing that , with the trailer ? thats news to me , did the dealer put stock parts back in ?
you should probably not go upgrade in OD , though your trailer weight isn't real heavy , down shifting at the bottom would probably help , but how fast are you trying to go with boat in tow ?
call bill , he will not try to sell you something you don't need , but honestly the stock TC is horrible .
[This message has been edited by Mopar-muscle (edited 03-15-2001). ]
Call Tony at Dunrite for info. He will steer you straight!
Find his # in the TDR advertisers. He is the most knowledgeable you will find!
