Chris,Im not doubting you hit 280,but I plowed this winter for 20 hrs at a time,going no more than 10-15 mph,with a 3500 lb Vbox spreader on the back,and a 980 lb 9'2" plow on the front pushing snow,sometimes wet and heavy and the highest i hit all winter was 210 hot line,the average temps ran 155-175 hot line plowing,When i hit 210 i was jockying back and forth for 10 minutes,in and never went more than 150 ft,doing tight pushing. I did this with a stock trans pan,cooler,and the 89% TC. i have never had a stiuation where i have been over 210,since then. I know the temps in winter werei nthe 30;s but the conditions were much more severe,IMo. . What gear was the truck in while you were going up the hills? It sounds like it was in 2nd,and should have been held in 1st,this would have reduced the convertor slippage,and dropped the temps. In your case there isnt a tc out there that would have helped you stay under 280,without driver intervention(manually locking it in lockup or holding it in 1st gr. For best performance therer are times times we need to step in and put these trannys in the right gear,I think this was one of those times. By design they shift too soon,up to 3rd. and this can only be raised so much before you start to have bad side effects like hunting,or late shifts empty.
