Torque limit?
Oil and Filter
5 Star Service, My A**!!!
You guys with 1-tons that are running with torque ratings of 800 ft. /lbs. or more, will the driveline and rear-end handle that o. k. ? If so, what would be the upper limit for these components?
Phil
'99 D3500, auto. ,2WD,3. 55 LSD, all options, Banks Power Pack w/K&N filter,DTT TC & VB, Mag-Hytec pan, '99 40ft. Alfa Gold Triple-slide 5'er
Ramboy, you must have caught that bombing bug bad, how close to the torque limit do you want to get? Maybe you'll just keep bombing until something something gives, then you can provide R&D info. I'm looking forward to driving your truck, I hope it's not too much faster than mine, could cost me some more $$$. #ad
Tom
Tom W in Austin Tx 98 24v 2500 Quadcab, auto, 3. 54, lsd, Rhino, white/driftwood, Banks Stinger Plus, 275 injectors, Manix grill, nerf bars , DTT's TC, valvebody, cooler, Smartbox, Mag-hytec trans & diff, Pac brake, Bilsteins.
Ramboy,
The torque rating on driveline components, and how much your truck is capable of exceeding them, is important of course, but just as important is how you load these components.
For example, in my Jeep, I have a Dana 44 rear axle. The axle shafts are rated @ approximately 5,500 ft. lbs. ; however, with my transfer case in 4 low, the Jeep is capable of putting to the ground approximately 20,000 ft. lbs. of torque, yet I have not broken a rear axle shaft (yet!). If I wanted to, I could snap my axle shafts like toothpicks. They don’t break because 1) I am generally distributing the torque among the 4 axle shafts, 2) rarely is the Jeep outputting the max torque, and 3) I try to use a smooth power increase whenever possible to minimize the force shock on the system.
Bottom line is that you can have an output that exceeds the torque specifications of the components and still use the truck reliably, but you have to understand that you are capable of easily breaking something, and you need to drive accordingly. This puts a constraint on you and how you operate the vehicle, so it’s a compromise.
Additionally, all mechanical systems break, the parameters to consider are the time interval before they break, and the time between breakage. The more you stress the system the sooner it will break, and the smaller the time interval between breakages.
So the answer to your question “…will the driveline and rear-end handle that o. k. ” is that it depends on how you drive the truck.
2001. 5 3500 QC 4X4 6-speed HO 3. 55 black
1998 Jeep TJ black http://www.nm4w.org/members/puffer.htm
[This message has been edited by PUFF (edited 04-20-2001). ]
Tom,
I was just toying with the idea of having the Torque Limiting Control feature removed from the Ottomind. I'm not sure I will like being capped at 650. If Peter T. is on here, what do you think?
Phil
Puff,
Thanks for the input. I am not much of a hot-rodder(unless I'm challenged) #ad
I just tow a heavy load and would like to know it's there if I need it.
Phil
Phil,
My understanding of the TLC-torque limiting control that Banks has in the Ottomind is that it is there for the transmission and not so much the driveline. Since you have the DDT TC and VB I don't think it should be a concern. Why not give Bill K. a call and get his input.
My 2500 is holding 760+FtlbsTq with no problems
Y2K(BD. 11. 18. 99)PW7A BE2L34,(A4OP=ETC/DDX),DMDP w/DSA,AHJ,Autometer Pyro& 50#Boost,STD. PE&EZ,sportbike injectors, PSA, Majestic HX40,4"exh. w/Stan's downpipe
