The biggest thing I pull is a 24' flat deck over axle dove tail tag trailer with a pintel hitch. It's 30' LOA and about 8' wide. Now, its already almost 5K unloaded. My loads vary, if I pull the tractor 10k, load it down with lumber, 12K to 14K comes quick. So, I think I need a WD set up to be safe in the eyes of the DOT officers.
My front end is never "light", the trailer supports most of the load. I balance the load over the axels of the trailer. The truck pulls it great, no sway, no bucking loaded. Its a rough ride empty when the pintel is light. The whole set up rides level if I can get the weight back far enough. My tractor loads the hitch more than lumber loads, because it takes up all the deck room with the loader and bush hog attached.
What would you guy's use on an 03 3500 dually for a WD set up pulling an equipment trailer? Have you seen one that will work with a trailer made from 8" I beams or bigger? I do have a ball type hitch that bolts to the trailer along with the combo pintel I'm using now. I use the pintel/ball type so I can use the 2" ball for my small trailer or the pintel for the larger trailers without changing the draw bar / ball mount. Hope that makes sense.
I've never pulled this heavy with a tag trailer, so I don't know what I can get away with. The following pics are of my trailer almost fully loaded with about 150 4x6s and 4x4's, its a good load.
Notice the truck is not very low in the back, I'll also need a bed full of sugar water for my newer bee hives. The truck still rides level with that kind of load, what a truck.
