towing speed limit
Magna X Mirrors
Towing 5th Wheel with Air Foil
what is the speed limit for 5th wheel,18,xxx#
In TX, AZ, CO, OK, UT, OR, NV, WA ?
[This message has been edited by JNutter (edited 12-21-2000). ]
JNutter, Here in Utah the speed limit is the same for all vehicle, although there are some canyons where anything over 10,000 GVW have a slower speed limit. The one I tow all the time is 65 instead of 75, but unless you have a sport car most cars don't drive much faster than 65.
Romeo here is the MTO site http://www.mto.gov.on.ca/english/trucks/ this is for Ontario, the regulations vary quite a bit across Canada, in Ontario the are generaly fewer restrictions than other places in Canada. Speed limits are the same for all vehicles unless posted as different. All vehicles that are considered a truck carry comercial plates, starting at the same cost as a car up to about 8400 lbs gvw. From what I understand you are required to scale any trailer with 2 or more axles regardless of what you tow it with although it does not seem to be enforced and our scales are badly understaffed so are frequently closed. Two other sites you could try http://www.ontruck.org/ and http://www.truckline.com
Neil
Neil Copeman 92 D250,LE,limited slip, 16cm turbo housing, Isspro gauges, factory tach option, Lear cap, DC crankdown tire carrier
Hadley air horns, Stealhorse leather seats, e-mail (home): bombedcummins@sympatico. ca
Here is the info for all the states. www.rvsafety.com/state.htm
Ron
'96 Club Cab 2500 4x4, 4:10LS, Camper/Tow package, Auto, BD Pressure Loc, Mystery Switch, TST 230/605, Cat under "Test", Cummins Chrome, Mag-Hytec rear and trans covers, Boost, Pyro and trans gauges, Optima Red Tops, All black. Tow 14k HitchHiker triple glide 5th Wheel. Also use 9. 5' Lance camper. NRA Life Member.
That rv safety site is not correct unless it is just listing secondary or 2 lane limit as the limit in NM is 75 for all vehicles on Interstates and 65 on 2 lanes
guess I'll start looking for sone 4:10's for the truck . #ad
[This message has been edited by JNutter (edited 12-22-2000). ]
