OD has been in and out sometimes (not really bad but thought a good cleaning would work). So I disconnected the TPS and cleaned the posts. I also tried cleaning around the big screw underneath the TPS. Took a screwdriver and made sure that it could easily turn left and right. I could feel it clicking by the contacts on the inside. Now doesn't shift into OD at all. Could I have broken a contact from inside? Is there a special way to put back together? The throttle part looks as though it is pointing to 11 o'clock if you consider the electrical connector is plugging in at the 12 o'clock position. To mount TPS back in, had to turn that screw just a little to have everything align up. Something so simple can cost so much... ;(
I am getting a price for new one on Monday, I assume about $200 or more. Thanks too all, stinks driving at 45 mph now.
Scott
92 Ram, Bright White, Club Cab, LE package, 4x4, 130K, 3. 54 gears, Auto, Extra transmission Cooler under bed, 285x75x16 Cooper Discovery A/T, 16X10 American Racing rims, Rancho RS9000 all around, Tekonsha Brake Controller, Running boards, Lund Sunvisor, Marker lights, Lund bug deflector, Tonneau cover, Full cap, DynoMax muffler, 5" Chrome tip, 16 cm Turbo, Isspro Boost gauge, 23 lbs Boost, Pump Adjustments, Sprayed in Bed-liner, Rubber mat
'SHAKES, RATTLES & GOES'
Scott
