Trac bar
Kilby Air compressor
Has anyone used these subwoofer enclosures?
Is anybody using the DT Heim Joint track bar. Click on the link and tell me what you .
DT Products & Fabrication
DT
I installed mine last year. GREAT product. Installation a bit more involved than other solutions, but you can adjust axle center easily once installed. Took care of lots of steering wander for me. I definitely recommend the DT.
-Deon
Just installed mine a 2 days ago. It's GREAT. The install is pretty easy, but you will probably have to grind down the metal sleeve in the bushing at the axle end in order to get it inside the mount-- it's a little too wide.
Also, getting the old track bar out can be a real PITA. Just grab a BFH and keep whacking at the mount until it drops.
Justin
Ive had mine and the Darin's Steering Stabilizer ( DSS ) And both working together are one sweet deal! With the desperate need for tierod ends (Drivers side) and upper Ball Joints My truck has next to ZERO wander on the Highway.
When doin' the install (Which is straightforward) Have a Right Angle drill handy to make life simple and a buddy with a tape measure so he can swap sides back and forth when doing axle centering. They only give you ONE alighnment guide tool when Two would be the ideal #
