Traction and Uping the Power
Truck started, ran 10 seconds, died, no restart:
Leather seat care and repair
Howdy,
I've got 10k on a 01 Quad w/ a 6 speed and have been trying to sort out all the info on performance upgrades. One of the problems I see, is how to keep the wheels from spinning? I spend alot of time on non paved roads. Letting the clutch out now, on a slippery surface, leaves me with spinning tires, and that's without touching the fuel pedal! How will any performance upgrade effect the traction?
TIA
Welcome aboard Frank,
You must work in muddy conditions. If your spinning tires now you will be really spinning tires with any power upgrade.
My last truck was a '97 5spd and I put in a TST fuel plate. hauling with a load was the main reason for my power upgrade. It made passing and going up hills a breaze.
good luck
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
Frankster, it's all about driving with due caution when your "bombed". My truck is still very controllable in the snow with the existing mods. , as long as I use common sense while accelerating. Just dumping the clutch in slippery conditions and from a start will spin the tires whether you have performance upgrades or not. Once the tires grab put the power on slowly and you won't have a problem.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Start using 1st gear more often and don't dump the clutch pedal.
-Mike
'00 2500,QC,4wd,LWB,Dark Garnet,6spd,3. 54lsd,SLT,DD stage II,Psychotty air,10-level PM3,Jacobs ebrake,Isspro pyro & boost gauges,2wd-low,Airoquip fuel lines,Smittybilt nerfs,BFG 285/75 AT's
'95 2500,Reg-cab,2wd,LWB,White/Driftwood,Automatic,3. 54open,SLT
run a search on steve St Laurents posts. He had some ladder bars made and says they really helped. I rode in the truck on sat adn can testify it hooks up really well. The bars are really neat looking too.
Scott
'01 3500 qc 5sp, 4x4 white w/ green graphics dark tint, flaps,K&N 0880 and pre filter, tonneau,painless, Uniden Grant LT w/3' glass K-40,aux. back up lights,
'91 Regal 260 at Dale Hollow
