I am looking at the Pro Comp traction bars.
they are bolt on, they do not get in the way of inside the frame air bags or even over the spring air assist bags.
price is reasonable also. they come in different lengths, depending on style of truck.
Pro Comp Traction Bars - Dodge
the 72500B set is about 51" long which is shorter than the 72501B set.
they also look like they will work on a standard height 2wd truck.
i have called Pro-Comp 2 times for technical advice and they have been very helpful both times.
i probably will be buying in the next week or so, along with an airbag assist system.
hope this helps
Jim
I use caltracs on mine.
Just call caltracs and get them for your truck. Easy!
did you buy the ones for the 1500 or something?
Mine are for 2500.
I cut my frame and made my
truck short box.
why do you say that? are the lazersmith bars the ones you make?
You are asking the wrong guy here. I don't make any bars. I have used caltracs on several trucks. both 2wd and 4wd, and have had good results.
LaserBob
The Lazarsmith bars are garbage. I've only had them on my truck for just about two years and they've rusted pretty bad. They're bubbling with rust along the entire length and the finish has flaked off in spots. They were powdercoated, but apparently there was no attempt at prep or material storage before coating.
Add to that the non-lubeable farm implement links used for rod ends, the crappy packaging, and the drama that ensued when I tried to get a replacement bracket that fell out of a hole in the box (due to the packaging), these bars are not worth the money.
Getting rid of the axle wrap made the truck drive like a completely different vehicle though, mostly plusses. Unfortunately, I'm gonna pull the bars off though; I don't trust the Lazarsmith "quality. " If the front end of one of these things fail and dig in, I can't imagine the hurt it would put on the truck (or me).
Traction bars = good
Lazarsmith bars = bad
do you have a recommendation as to a good set? i am thinking i still might make my own as i am very particular and have a very good eye for attention to detail. in my personal opinion i can probably make them cheaper and better then what i can buy them from anyone. but i will say i am always willing to consider the purchase of a produce thus the reason for asking.
