Engine/Transmission (1998.5 - 2002) Trade Gear Vendor OD for stock Setup?
2nd Gen Non-Engine/Transmission Build Sheets
Is anyone interested in a trade, plus cash of course, of my Gear Vendor OD, transfer case and rear driveshaft for your stock transfer case and rear driveshaft? I have the system installed and working fine in my truck. This would be a very simple and low cost way for someone to get into this over/underdrive setup. I figure it may be easier to swap transfer cases as well the OD, but maybe not.
The ONLY way I would do this is if the other party has the same drivetrain as mine had originally, and has the same wheelbase. Mine is a 2500 6 speed 4WD Quad cab. This way, it is simple for both parties, as we get all the rear driveshaft pieces we would need without the time and expense of locating, fabricating or paying for them to be made. (When the GV is installed, the rear carrier bearing is removed and the shaft is shortened). Having the right pieces, we could do a swap on both trucks pretty quickly. I have a shop at home with plenty of room and tools. :)
Please contact me or reply if you're interested.
Why are you doing this; no like GV?
Curious as to why you are doing this? Do you not like the G. V. I am considering a G. V. but I am short bed and a long ways away from you?
I do like it, but I don't really need it for the type of driving I do. With the 6 speed, I do OK without it. I bought the truck used with it already installed. It appeared to be newly installed or recently replaced at the time. That was about 12,000 miles ago. I'd prefer to go back to stock, and get a little money out of it to put toward engine BOMBs that I would get more use from. :)
