I found and saved this from Airforums a while back. Maybe this is what he is referring to.
WARNING!! New 2013 Ram Truck - Brake Controller, Aftermarket
From Cequent Performance Products
TECHNICAL BULLETIN: TB13-01
Issue Date: 02/01/13
Installing Electric Brake Controls – 2013 Ram Trucks
Vehicles - 2013 Ram Truck - All
Product Family - Brake Controls -All
The electrical system on the 2013 Ram trucks has changed. Though the brake control connector is the same as the 2010-2012, the wire functions have changed. The terminal that used to be the stop light signal, now has battery voltage, whenever the ignition is in the run position. According to Dodge, it is not possible to install an aftermarket electric trailer brake control into these trucks. Dodge says, that “the 2013 Ram has “Powernet” and utilizes multiplex wiring that is different from any previous design’s, therefore, your aftermarket trailer brake control is not compatible”
At this time, the only aftermarket brake control that can be used on a 2013 Ram truck, is the Tekonsha 90250 Prodigy RF. As soon as more information is available, a revision to this technical bulletin will sent out.
WARNING!!! - Any attempt to install an aftermarket brake control into the vehicle, may cause severe damage to the vehicle’s electrical system or electrical component!
__________________
Patrick & Lauren Botticelli - Colonial Airstream 1121 Route 88 Lakewood, NJ 08701 - 1-800-265-901
www.colonialairstream.com
