Details here: TDR Privileges
95 ram 2500 with factory toll package. I would like to install a reese brake control on my ram is there a factory plug for this if yes where if no what is the best way to hard wire. any help appreciated thanks GBAX.
Look down by the pak brake assy near the large wiring connectors you should see a flat blue connector with 4 wires.You should be able to purchase a harness that plugs right in.
Bob4x4 thanks for responding, I could not find such a plug. At the lower left their is a single blue wire with trailer brake on it. my 95 was built in December 94, maybe this was before the plug-in was installed, I don't'know. again thank you GBAX.
The trucks were built in a number of configurations.In your case you will need to wire it in the old school way.You will also need to wire the trailer lights and power from scratch.Their was an accessory add on kit from mopar but I doubt that will be available still
BOB4x4 gain thanks. I went on and wired the old way. Sometimes there are advantages to newer vehicle but this old p7100 powered 5.9 sure is sweet. again thanks GBAX.
