Ok, i'm working on wiring a trailor I built. I just put a Prodigy in my truck with there Dodge wiring harness. I plugged in the trailor and the Prodigy showed the brakes were not hooked up. So I unplugged it, had someone hold the brake pedal down while I check the plug on the truck with a tester. Everything worked except the trailor brakes, and battery (hot) prongs. Will the trailor brake prong not have any current going to it unless a trailor with brakes are hooked upto it? Is that the same with the battery (hot) prong?
