I replaced my optional OE trailer hitch with a Reese Titan V hitch this past week. What an awesome brute that thing is!
I would like to note that two of the four required mounting holes in EACH side of the hitch mounting leg had to be drilled through the HITCH on my '98. 5 LWB QC. The two holes that require drilling are #2 and #4 (assuming hole #1 is the REARWARD most hole). "Loosely mount" the hitch, scribing the hole locations that will require drilling, through the holes in the frame onto the hitch. I was told by Reese that this was necessary because this custom hitch fits such a wide variety of years and configurations (RC, CC, QC, SWB, LWB, prior as well as post '93 model years). I know one thing, it looks like Cummins designed it!
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Reese Titan V hitch, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, Reese Titan V hitch, plus many other trick modifications
