Trailer Wiring
Camparison Test? Really?
3.71 vs. 4.10 rear axle
I am getting ready to install my 5vr plug in the bed of my truck but have a question for those of you that are in the know. My 7 way connector is wired (color coded) to match the diagram on http://www.klenger.net//misc/7-Way Connector Wiring Diagram.gif
Which reads
White=common ground
Blue= electric brakes
Green=tail & license
Black= battery charge
Red=left stop and turn
Brown=right stop and turn
Yellow=center auxiliary
Now my question is in the towing package on the truck, what wires splice to which wires. The wires in the towing harrness on the truck don't match these colors... . TIA Phil:confused: :D
This is a sketch of the wiring of my truck when I added the camper plug in the bed. Hope it helps.
Edit: 12/07/2002 See later post for correction.
klenger, the pic was a little fuzzy. But this is what I took from it:
Plug Truck
black > red/orange
brown > brown/red
blue > blue
white > black
red > green/orange
green > black yellow
yellow > black
And I'm assuming that the second color is the color of the tracer stripe... . :cool: Thanks for the help! Phil:D
Wiring diagram
For you lucky folks with a wiring diagram for the 2003 trucks can you look up for me:
The size of fuse providing power to the brake circuit.
Where is the ground circuit for the brake control attached or located. Thanks.
Casey
