Trans Temp Light
EGR in 04's? Here is what Dodge has to say about it!
cranking times
Hi Guys;
I thought I would throw this out to you Guys. I have had some intermittent problems with my Trans Temp Light it seems to flash for no reason. Also I get some times where the info center chime goes off for no reason.
First Time it happened it was Cold weather, second time it was wet weather, third time yesterday it was dry just as I started on a 400 mile trip into my first hr, and never happened again.
Any comments! Please help!
Brutus1
2003, 3500, Black Dually, c/w Lam, Spot Pkge, Q Cab, HO Cummins, six speed. :confused:
Are you sure it's not the check gauge light flashing. There was a problem on some 2003's with the check gauge light flashing for a second. I had it on my truck and a simple re flash of the computer fixed it.
The first time it blipped I was not sure what light flashed so I got out the owners manual to check the diagram and the trans temp and check gauges are right next to each other so maybe you saw the check gauge light. Either way it sounds like a re flash is in your future.
