Here are the parts required to convert a 1985 NP205 transfer case to accept a 360 Getrag 5 speed transmission.
Note: IF you want to use a Larger size U-Joints that the 1989 to 1993 Cummins trucks use you will also need to change the output shaft and bearing/housing as well.
I got these part numbers from the invoices that my Dodge dealer gave me. PLEASE check the Part Numbers before ordering anything.
Hope no one gets sticker shock
Hopefully someone can find a cheaper source for these parts.
ITEMS FROM DODGE DEALER
Part Number Name What I paid
4428408 BRACKET T 21030416 $65. 50
2960192 RING INPU 21009023 $1. 48
4505305 ADAPTER T 21085009 $364. 00
4505307 GASKET AD 21004003 $3. 00
2124518 RING SNAP 21009023 $1. 80
3820892 BEARING I 21005001 $52. 96
4269183 SEAL OIL 21060012 $6. 36
4340247 GASKET TR 21004003 $1. 53
517351 GASKET TR 21004003 $1. 89
4210976 GASKET GA 21004003 $1. 53
4210975 GASKET OU 21004003 $1. 35
4505316 GEAR INPU 21005003 $206. 10
4505302 SLEEVE IN 21030034 $58. 00
Total $766. 98
Also needed, two shifter rod seals.
Main case of the transfer case needs to be machined to accept new and larger input bearing.
Machine work & tanking of case ,cost $50. 00
Best of luck,
Kyle
