99 RAM leaking from transfer case? Been leaking awhile now but unsure where from. ATF on underside of bed but cannot find source other than transfer case constantly low. Appears to be coming off u-joint at output from transfer case but u-joint is completely dry! Rubber boot at output shaft from transfer case is also completely dry... . No fluid what so ever! Undeside of bed directly about furthest u-joint coming back from transfer case is wet though... . This would be the 1st u-joint coming out the back of the transfer case.
Logical assumtion would be the seal at the rear of the transfer case but it's completely dry at the boot where the weep hole is. This thing is driving me nuts! Suggestions?
Thanks,
Clay
Thanks,
Clay
