Details here: TDR Privileges
My nephew grenaded the transfer case in his '95. He has access to a case from a '01, gasser. Both are 4x4 and automatics. Would the '01 case be a direct swap? Thanks.
if he needs a transfer case i have one out of a 94 12 valve automatic it has 90k on it and worked flawless when i took it out. i will take 375. 00 plus the shipping
If he has a 2500, auto, It "should" be a NP241 LDL with 23 spline, female, input shaft. If he has a 3500, or a manual transmission, it "should" be a NP241DHD. I believe the DHD is a couple inches longer, to allow for the wider chain. 1500's use a NP231 case. There should be a round idenyifyer tag on the front of the case. Hear is a link to drivetrainparts.com to help cross reference. Good luck.
