transmission adjustment
Power Button,need info!!
Help: EGTs not coming down at shutdown??
95 Dodge 4 speed auto with 47rh trans. I changed to Amsoil. The national jobber for Amsoil suggested the bands should be adjusted also. So I figured, looks simple enough so I set them by the book, 3 turns out for the rear band and almost 2 for the front. Now it slips in low and shudders between 2nd and 3rd. I've tried settings down to 2 rear band and 1 and1/2 on the front. No Change. Any suggestions? It worked perfectly before I messed with it. Rick Thomas
First: You are checking the fluid level with the trans hot and engine in neutral, right?
Go to http://www.gbtransmissions.com/
Give him a call. Very knowlegable and helpfull guy.
'94 3500 4x4, 210,000 miles, Never had a cat, Auto w/shift kit (thanks Dave G), 3. 54 Gears, TST #5 plate, 235-85-16s, Rancho 9000s w/remote, Isspro Gauges & Amsoil Air, Oil & Bypass Filters & Lubes, AWOL intake boot.
Punchlist: X-Mount Mirrors, 14 cm Turbo Housing & 215 Injectors.
NRA member.
Blue Ribbon Coalition member.
"Warrantee? We don't need no stinking warrantee!"
