Transmission Buyers (Caveat Emptor)
Latest auto trans thread
New shocks
The DTT setup on my truck has 2 custom coolers mounted up in front of the radiator. I've been driving it for about 6 weeks. No problems.
These coolers were relocated to optimize cooling features.
The other trannies all used the stock setup. If there was anything other than stock from the other vendors it was not mentioned or offered.
Thanks for the tip Stefan. I will check for the valve on a later date.
Does this mean I am not getting proper fluid flowing in park with the check valve in? It has been 100,000 km's since I had my BD VB put in at a Dodge dealership and they were supposed to do it way back then. Then the shop that put in the DTT probably would not have checked either. :rolleyes: I guess if I want it done right... ... ... ... ... ... .....
couple of thoughts
The check valve in the cooler line fitting will restrict flow some in all gears. As to some of the trucks that heat up in unlock at low speeds and low or second for sustained periods, this is more of a result of low air flow across the cooler combined with being in fluid coupling. The position of the stock cooler does not get air pulled across it by the fan. It relies on road speed. Those trucks that pull in these conditions would benefit from a fan on the cooler to provide added air flow at low speed. Also, the amount of fluid directed to the cooler in fluid coupling is less than when in lockup.
Synthetic fluid will hold up to occasional forays into the hot zone longer than regular ATF,while with regular fluid, it will begin to break down sooner and should be serviced more often.
I saw in another post about a company that had a small fan that would fit between the cooler and the grill. Mattson I believe it was.
The coolers mounted in front of the radiator to allow for the fan to pull air through them would eliminate the need for electric fans.
My . 02
James
Just to add a little light of reality to this thread!!
I have been on this board long enough to see that EVERY after market transmission producer has product problems of one kind or another and they are continueing striveing to improve them. The longer one is in business the more complaints there will be.
Some people have had bad experiences with our beloved Ram diesels, I hope that doesn't make them all a pile of junk.
Ron
As the old saying goes; "there are two sides to every
story!" I will also be curious to see what Clint Cannon
@ ATS has to say about what has been posted.
"cabrokr"; I am sorry to hear you have had so much
trouble with your ATS transmission. My experience
with ATS and how I have personally seen them take
care of their customers has been TOTALLY different
than what you describe. Both my son and I have
the Stage IV ATS transmissions in our trucks (1996 &
2001) and they have performed very well! Prior to the
ATS I had a "Pro-Torque" TC, BD Valve Body, BD Pressure
Loc which was built and installed by Scheid Diesel that
I put over 70,000 miles on with no problems @ all.
We are both over 400 H. P. and I regularly tow heavy
trailers with my truck.
I also have a good friend who has the ATS transmission.
(Rammin On). At the recent TDR Rally, he experienced
some problems with his unit while towing his 27' travel
trailer from Colombus Ind. to Terre Haute, Ind. I ended
up towing his trailer for him and he eventually got his
truck to Scheid Diesel a few days before the rally. He
called ATS and spoke with Clint Cannon and Don Ramer
about the problems he had and they told him they would
ship all the parts neccesary to fix the transmission and
fix it before they arrived for the vendor show. The next
day they arrived and Dan Scheid allowed them to use
his shop to do the repairs.
For over four (4) hours, I watched the owners of ATS
(Clint Cannon and Don Ramer) COMPLETELY disassemble
and then rebuild that entire transmission!!! They covered
EVERYTHING under warranty for "Rammmin On" and even
gave him a brand new ATS Electronic Controller for FREE
for the his trouble!!! When he pulled out of the shop later
that night the transmission worked great and still is!!
IMO, this there is no better example of "backing your
product" and Clint Cannon and Don Ramer showed
me they will do that because I was there to see it!!!
I hope that "Rammin On" will see this so he can add
to what I have already said. One last point, I also
"paid full retail for my ATS transmission" and I "don't
owe anything" to anyone either! After seeing what
happened in Terre Haute, I know that if I do have
a problem with my unit ATS will take care of it.
All of the major aftermarket Dodge Diesel performance
transmission shops have customers who have had
"problems" with their transmissions, including DTT!
This is not a "cut" on anyone, just a simple fact! It
applies to all parts on our trucks.
John_P
Veritas
Cabrokr AKA: David Drown
When a post like this is sent out to the public there is usually a little more behind the scenes. I am going to start by filling in some of the gaps that DD left out of this post. The first I ever heard of DD having any problems with his transmission was when I received a call from DD telling me that Piers from PDR had disassembled the transmission. I was a little surprised to hear the transmission had been disassembled in the first place and very surprised to hear that Piers had disassembled it. The first step with any warranty issue is a call to the warrantor first, I took it as no big deal. Piers and I have had many conversations about transmission work in the past and he has always made it clear to me that he wants nothing to do with internal transmission repair. I immediately called Piers to verify what was going on with our transmission and he said the forward clutches were burned up. I asked Piers if he was doing the transmission work and he said no not really, some one else was doing it in his shop. I was a little confused at this point… then I said it must be Bill K from DTT. Pierce said no, I said ok?? Pierce said he needed some time to finish the engine build up so there is no huge hurry. I told Piers that I would send up a Billet input shaft and Hub along with loaded clutch drums. Needles to say things seemed kind of fishy?
The next thing I knew there was a post on the TDR from Stefan K from DTT advertising free insider pictured of ATS’s stock transmission. Kind of funny that a few days after the transmission is scattered there is another attack of the DTT boys. This was the 3rd time a major attack had been staged by Bill K owner of DTT. The first time was at May madness when Bill K. attempted to discredit me during the transmission seminar. A barrage of attacks regarding the ATS transmission and torque converter. We never promoted what had happen there, now I have no choice. Bill was warned to stop battering several times before being escorted from the seminar. It was a big embarrassment for him and all associated. The 2nd time was full blown photographs of an early TripleLok converter, pictures of the TripleLok is ok, the multiple post of how the TripleLok clutch system will not work is not. Strange that the fact is the TripleLok clutch system works perfectly in all the units Ford, Dodge, Chevy. That’s about 1,150 sold this year, they work regardless what some “one’ may say. The 3rd time is the incident we are working up to here, secret photos of ATS “stock” transmission. The pictures were taken somewhere ?? Figuring out where? I don’t feel slamming and fabricating negative information about a competitor is a professional way to promote your business. Some fell this is ok, not me. Because of my beliefs and integrity I have chosen not to point out the competitors faults. We have not taken the numerous opportunities to discredit the DTT products, and yes we have had plenty of opportunities. Take a look at the number of DTT steel stators we have in our collection that have come out of converters replaced at the ATS install shop. Enough said about this.
QUOTE: DD
Sent my truck up north to be modified. They took out the transmission to do my mods after 8-9 months of ownership and the forward clutches were toasted in 3rd gear. Upon further inspection of the interior of the unit: 4 clutch pack (supposed to be 5) Factory stock apply lever 3. 8 ratio, 727 stock band, factory band strut, factory sealing rings, and that special VB--a transgo shift kit!
About the transmission internal components, 5 clutch pack high/reverse clutch drums have been used in all of our transmissions for about the last 2 years, strange a competitor disassembles our transmission (who ever it was) and finds a “stock” clutch pack? Factory stock apply lever, yes we do use the stock ratio. We do not reduce/increase this ratio because there is not extreme pressures acting against it “extreme line pressure”. We have also never advertised changing the apply lever. The bands and clutches are cellulose or Kevlar, depending on the application. The 727 “stock band” is a Borg Warner; the Borg Warner band has the highest coefficient of friction available. That special valve body. Where do I start. First of all in order to achieve 1st and 2nd gear lock there are 7 steps, 3 valves and 2 springs that are changed or modified. The separator plate is built by us, laser cut along with several spring changes and a few valves that we have designed and build. There are some major differences between our valve body and a stock one, if you know what you are looking at.
QUOTE: DD
I was very unhappy! In speaking to the owner of ATS he neither denied or refuted these facts, but instead tried to twist the facts of our initial conversation to his benefit. After several heated conversations with C(owner) ATS. The seller of said unit (ATS) tried to take my place as victim and subjectively put all the resposposibility of breakdown on me as consumer when I never ever abused the transmission at all. It was agreed between us that he would replace the unit under warranty.
When I (Clint Cannon) was contacted by DD the conversation was not heated as I recall, David was upset, it took a few minutes to calm DD down then we had a some what normal conversation. As far as putting all the responsibility of breakdown on the consumer THAT IS A LIE. Maybe it was heard wrong, I don’t know. There was no argument about the warranty, there is a 3 year warranty on the Dodge transmissions and TripleLok Converters we sell here and that is that. When the transmission was purchased originally we talked about the input shaft possibly needing to be up graded later to handle higher power levels, that was fine at the time. We were also under construction of the billet input shafts and hub so they were not available then.
QUOTE: DD
It took over 12 weeks of downtime to get a warranty replacement unit. Meanwhile back at ATS there were several sponsored customers who had broken down months after me and had their new unit within a week!!! I know because I saw them post on this site.
The 12 week down time started when I first received a call from DD stating that his transmission was torn down and the engine had been removed from the truck. At that time we were back ordered on billet input shafts and did not look like we were going to get any for a few weeks. I spoke with Piers and DD about the options and we decided to give it a few weeks so we could complete the orders for the Billet input shafts. A small order of Billet input shafts and drums finally came in and the transmission was assembled. The day the transmission was ready to ship I received a call from DD wanting me to send the transmission to CA. (Knot knowing the transmission had been replaced at this time with a DTT transmission) Now the transmission is going to CA not Canada, I asked DD how he got the truck home and DD said I had them put the transmission back together and I drove it home. I said ok, we will get you new ATS trans to CA and get it installed. For the record DD received the first Billet input shaft and drum from that run and there were and still are orders placed prior to his disassembly that are just being filled.
QUOTE: DD
And by the way that ATS warranty unit. They billed me for it. !! Shipping both ways, an upgraded input shaft, and a HUGE core charge. Not to mention the installation I will have to pay for if I put it in. I had another heated conversation with C(ATS) owner and he said that if I send back the core he would give me a -0- invoice showing paid. I had to really fight for that. I don't like or condone this type of stonewalling from the Manufacturer because it takes all the fun out my hobby.
Picked up a copy of their(ATS) warranty in writing and read it over. Everything in it is subjective! Basically if they don't like the way you dress you could be out of luck!
DD was billed for the Billet input shaft, drum and shipping charges. The core charge is for tracking purposes only unless it is not returned. Cores are a detrimental part of our business, with out them it makes it very difficult to service out customers, kind of like not having input shafts. The next time I received a call from DD you could say it was heated like fire. I can certainly say it was the most abusive conversation I have ever had in the 10 years of owning a transmission/converter shop. There were more F words and I would kick your F-ing ass if your shop was closer than I can repeat. There were About 5 minutes worth of this before I could get a word in. After I was able to talk to DD in very short sperts between the F-words I asked him what he felt would be fair. I said fine DD, what ever makes you happy, I already sent the trans out. If you don’t want to pay than don’t pay. DD did ****** off and hung up on me. David you hardly had to fight for the –0- invoice. Any one that knows me knows how I am about that, about as calm as they come. Unfontantly the delays on the billet input shafts and hubs positioned us in a spot that made it impossible to deliver the product, I am guilty of that. As far as the warranty, I doubt you will find few companies that will stand behind a warranty as we do, ATS. Ten years in the transmission and converter business does not happen on accident, customer service and quality first.
Clint Cannon
ATS Diesel
I have posted the facts about what was found in the interior of the transmission. Misrepresentation is the non disclosure of a material fact. Which constitutes fraud. Fraud is a felony in state of California.
To state factually:what was found in the transmission is not what I paid for, and Why would ATS bill me for something they would so graciously waive?
Another penal code violation in the state of California known in ther judicial process as overbilling.
. . I take an evening to get a few errands run and see what happens!!!!
I was the guy David got to do a little prodding and when I called it was just as Clint said... waiting on parts. When the parts came in they shipped it right out.
It's unfortunate that laundry has to be aired in public.
Clint, Don, Renee and the rest of ATS have been very helpful, courteous and kind. They are a good bunch of folks that have excellent products and in my experience excellent customer service.
David Drown is handling the loan on my house. He too is a fine businessman and I consider him a friend. It's just too bad that he felt he didn't get the treatment that he felt he deserved, reguardless of the reason. However, I am disappointed in the way handled himself on this matter.
You can't please everybody.
I wouldn't get a loan from anyone other than David.
AND
I'll be going shiftless in a few weeks. The ATS stage IV is the only auto that will be in my truck. PERIOD.
FWIW,
Mark
Oh yeah,
If you have a grievance about my post don't you think it would be better to keep it between you and me? Why bring others in when not necessary.
What about that transgo shift kit?
Do you think that a 4 clutch pack accidentally got by your quality inspectors?
How bout that stock apply lever?
Any comments about what is REALLY included on the interior of your transmission?
The warranty issues and your lack of customer care is not really my main concern, but the actual facts about how you install substandard parts is.
DD, I find it strange to believe you when you lead the ATS shop to believe that Piers was doing your transmission work and your trans wound up at DTT. Then you have a competitor of theirs who obviously wants to try and slam them every chance he gets (witnessed at May madness by all that were present at the seminars) tare down the transmission. I find it hard to believe these finding when it seems to have been staged. Further more you are now conveying the message of fraud. What should be said for slander? DD I am not attacking you, I just think that you may have been mislead by someone looking for a chance to slam ATS when you had a moment of weakness. Good luck to you in the future. All I can add to this is that all of my experience with ATS has been very pleasant and honest. Yes I am a paying customer.
Clint ,
I am not sure where you anger stems from as my Dad did not touch your transmission. As a favor to Piers Harry / PDR my Dad finally agreed to sell David a Billet Input Shaft and hub as you were not able to provide him with one, eventhough your customers on the internet were encouraging people to them as you had them available. Remember the thread John Connely posted on saying that you guys were buying from the same company as ours only to later find out the info was false.
Staging stuff, being escorted out of the seminar at May Madness, have you been drinking ? Do you know how many people were present at that seminar that know that is a false statement.
We will not apologise for trying to help Piers or especially David who had been waiting weeks for help. It was only after he could not resolve things with you did we even sell him a transmission .
Your issues with David are with David, don't try to punish us for helping somebody that was stranded.
As far as my dad is concerned he was doing Piers a favor by helping David . You want to call Piers a liar thats your deal.
Just Some Facts To Add
David
We want to just let you know that when you had that transmission disassembled by someone else without our consent that technically voided your warranty. However we wanted to help you and proceeded with support.
The part that is really hard to get over is the fact that you could not be honest with us when we were sending a replacement transmission. By doing this how could this help your credibility after the fact? When you took the truck from Canada to California and also telling us that our unit was repaired was indeed a lie. How could it be repaired when you drove home with a DTT transmission. Please also tell others how you could not supply the facts to all of the readers. David what part of this would be dishonest? Now that we are airing this in public please return our core and as for the second transmission you have in your possession belongs to you. As for the warranty it will stand as states in the warranty contract that if we wanted to would have been voided.
Don Ramer ATS Diesel Performance
DD
I will copy what I explained earlier (((That special valve body. Where do I start. First of all in order to achieve 1st and 2nd gear lock there are 7 steps, 3 valves and 2 springs that are changed or modified. The separator plate is built by us, laser cut along with several spring changes and a few valves that we have designed and build. ))) I will make it simple, it's not a transgo shift kit? This is also a good time to bring up the thought,, who would know what a transgo shift kit looks like. We all know the answer to that one.
No, we have not built a 4 clutch in 2 years
Again: from earlier post
We have an open door police, come down and see for your self.
Clint Cannon
ATS Diesel
Just for all to know:
When I first called ATS regarding a trans upgrade. Clint got on the phone and the first thing out of my mouth was. "I want the biggest baddest thing on the planet and all the fun stuff that goes with it like twisted driveshafts, broken rearends and the grief associated with that kind of horsepower. "
They laughed and said you came to the right place. Our torque converter holds 1750 lbs. of torque before it breaks away on a bench test. You will have other broken parts like you mentioned before you break our transmission.
Obviously not true.
Remember I was only running 350-400 rwhp at that time.
I am reasonable, I know everything breaks and I overlooked this statement, because I am in sales as well.
There is enough business to make money honestly without having to misrepresent your product.
I am simply stating I did not get what I paid for.
As for the installation at DTT. they were the closest and most convenient. The obvious solution for a problem based in Canada while I am in California. Before the install you're always skeptical about if it was money well spent.
It just happens that it was. I find it to be a superior product to ATS. I only waited to make this post in fear of losing out completely with ATS, and give time to test the new DTT and see if I was right in my initial assessment of DTT trans.
Most reputable people in this forum know what vendors are truthful and after 12 weeks the majority would venture to speculate that after 12 weeks you probably won't get anything, you're just being led on.
Originally posted by Stefan Kondolay
Clint ,
I was at MM where Bill made a fool of himself. He showed up w/o registering and tried in vain to hecle the seminar.
You have a history of posting pictures of products that you have disassembled and displayed out of context.
For Piers to not do transmission work he sure knew a lot about the finer points that nobody but the mutt-pack could have told him.
I'd take a transmission that Clint assembled drunk over a DTT anyday.
Originally posted by LSMITH
IF the BS childish ranting (on ALL SIDES!!) can stay out of this thread MAYBE some valuable information can be gained, as I expect a statement will be made by ATS. If both sides of this can present their case reasonably (one has already) we will all have information to use in our own decisions. I really hope the cheerleaders for both DTT and ATS go home, put the pom-poms away, and come to this thread as adults.
I usually never post on stuff like this but ::::::::::::
In the beginning Bill K was telling all of us about this stuff that was being sold. He was ridiculed and called slanderous. Even got himself kicked off the boards because he was trying to convey a message to all of us. I hope this is a one time instance with ATS. I for one would feel sorry for the guy who dropped $4K
twice. That hurts... ... ... ... ... ... ... Greg
GLASMITHS,
I guess in a way we in the DTT family are mutts, we come from all walks of life, different colors of skin, different political beliefs, ect.
HMM, i think i feel a new t shirt comming on.
Na, i think we will stick with the wolf pack.
