Yesterday on the beach chasing stripers in the surf I had to move my truck and the sand being so soft I had problems. I had to put truck in low range and I only use 1st or 2nd most of the time. Well I didn't and trans made a grinding sound
I thought that the transfer case wasn't in gear all the way. Long story short when I got on to high way the trans seemed to shift funny I stopped and there was a little fluid at the inspection plate under the converter. I drove some more and everything was fine until a block from home and no overdrive it won't shift it's like the od switch is off. The fluid is dripping just a little. It doesn't look bad or smell. The trans was completly rebuilt almost 2 years ago. Any ideas what this might be. I'm going to call the shop Mon morning but I thought I would ask just assuming the worst.
