transmission lok ups
100,000 mile oil changes?
bedliner or bed mat?
Originally posted by john decker:
I haul a horse trailer and want to install a pac break what do you all have in the field that works.
Check out www.dieseltrans.com
They have a new e brake contoler that will be available soon. give them a call
2K, 2500,Laramie,Quad,4x4,3:54LSD,auto,reese 15k 5th slider, EISLEY BULL BAR,WESTIN NERFS, TA's,9000's, DD1's,PE-EZ & elbow, ISSPRO pyro & boost, JARDINE 4", DTT VB,TC and COOLER, PAC BRAKE, MAG HYTECH TP, onboard.
pullee #1 26' Arctic Fox 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA,VFW,SASS
John,
While you are checking out the above web site you may want to consider this.
The auto lock is nothing more than a mystery switch and a speed sensor set to dis-engage at approx. 30 mph.
Things to remember:
Everytime you forget to dis-engage od when de-excellerating, you are damaging your tc and your drive train.
You have to remember to accelerate to de-excellerate when comming out of overdrive.
Does not allow you to have 2nd gear lockup.
I predict that 2001 is going to bring a lot of good changes for the Dodge Ram owners as far as exhaust brake control systems are concerned.
Bill
Diesel Transmission Technology
John... Do you have the automatic transmission. That seems to be something everyone is assuming... Arlan
I just re-read the Topic Title and it appears that you do. Bill is correct on the topic of the Torque Lock it is no more than a glorified mystery switch, only as good as the users ability not to make a mistake when using it.
[This message has been edited by arlan (edited 11-19-2000). ]
