Dern, I was hoping to finally put the arguement to rest.
I still have a few questions though.
Where is the big savings, in dollars, to the consumer to use the Amsoil over the Syntorq? Syntorq is 54 bucks a gallon. Amsoil is roughly 40 bucks a gallon. Is 14 bucks the big dollar difference in price you guys are preaching? Castrol has all this money to freely give to John Force from Syntorq sales?
Dynos may not load the engine and drivetrain like the road would, that I agree. How else could you keep the tests the same?
Driving on the road could never be duplicated easily. Traffic, stop light timing, etc. is always different. The oils on the dyno would be subjected to the same stresses. This way we have controlled testing.
Im of the opinion that the Amsoil will heat up faster and exceed the safe limits of the transmission design. Rheologically the Amsoil is not close enough to the Castrol Syntorq. The climbing and/or clinging properties of the Amsoil does not allow it to adhere to the gears. Remember the NV4500 is splash lubricated.
Would the Amsoil require the truck to be moving around to splash the oil around during cornering?
Do either of you really feel that DC is making a ton of money from oil sales? That position sounds kinda dim to me.
I still feel the dyno test would show which lubricant would heat up faster under controlled conditions. I have a good feeling the Amsoil will fail miserably at controlling heat.
Gene, your Syntorq could have been contaminated from all sorts of things. You, of all people should know that. I do agree that Syntorq or any oil should not be left in for 100,000 miles.
You are quite the salesman it seems. If Enterprise went to using Amsoil for the NV4500 after just seeing the condition of your oil alone, you are truly the best salsman I have known.
Hammer, the term brainwashed is applicable to both you and Gene as well on the Amsoil. You ignore the heat tests and HP drag tests from Joe under controlled conditions. The FACT that the manufacturer of the transmission, rebuilders, DC all say to use the Syntorq. New Venture Gear wrote a spec for transmission oil and the Castrol meets the spec. Now whos really brainwashed?
Me, the guy who has nothing to gain from the sale of Castrol? Or Gene and you who sell Amsoil?
You are one of Genes dealers correct? You know, the guy who gets the stuff a tad cheaper that is under the guy who signed him up, who is under the guy who signed him up, and on and on. Like building a tetrahedron or pyramid
Lets test the oil and see which one can provide the protection we need.
Don~
