I have had this problem shortly after installing a new vb & t. c.
I was getting hunting in and out of lock up at 40-45mph. there was no way to tow. and have had many vacations planned . attacking the problem the best i could, using info sights, and turbo diesel specialists. i also took it by the dealer. after a short drive they said, pull out ,and replace the v/b with a stocker and we can work on it. I no longer had a stocker so i went down other avenues.
since then , i have tried the happy box . cleaned the Bat's. reset the apps, replaced the solenoid gov. replaced the o. d. speed-sensor, removed lock up box, had an updated re flash.
installed a second v/b. All this was not done exactly in this order. the bottomline is, yes, i still have the same problem . and also a new little glitch where i get a fast 2-3 shift. I have no idea were to go. any info would be appreciated. thanks, Robert, stuck in sandiego
