I have a 2012 2500 crew cab ST w/ 4WD; rear axle is 3. 73 ratio, automatic transmission.
I purchased a 1995 Jayco travel trailer - it is a bunkhouse model. The tag on the travel trailer says 7800 lbs.
(1) I used the towing calculator on the ramtrucks.com and figured:
Two kids, two dogs, one wife, and all kinds of stuff adds 1200 lbs to the truck
All kinds of stuff adds 1200 lb to the travel trailer (now travel trailer at 9000 lbs)
ramtrucks.com says that, loaded as above, I could go as high as 11,500 lb trailer
My thinking is that I am well within capability of truck
(2) The truck is all stock now, and my thinking was only to add:
An aftermarket transmission fluid pan - increases fluid capacity by four quarts. Thinking is more fluid equals lower fluid temp when towing.
A front end steering bracket - looks like a piece of frame rail to stiffen up the front end steering - I understand weakest link of the truck is front suspension
A rear anti-sway bar
Brake controller
(3) I am concerned about the suspension on the trailer. It has two axles, and I need to learn how to determine what capacity they are. But, I think the travel trailer should have:
Two 5200 lb axles (and corresponding springs)
I plan to replace tires with new load range E tires - these ay rated at 2500 lb
I plan to replace brakes
It looks to me like it will be most cost effective to replace the entire axle and suspension assemblies at once - thinking Dexter but open to others if folks know what is quality.
Also - weight distributing hitch.
I think I should be set up to run forever and a day at that point in total safety. Just wonder if those who have had a few more trips around the block than me agree.
P. S. - I never paid attention before, but drove back from Florida a couple of weeks ago. We were just going - not pulling the trailer. Lots of trailer RVs on the interstate. A lot looked bigger than what I have purchased - and being pulled by 1/2 ton pickups - Ford F150 common. Don't really see how safe that is. Even more surprising - how many times I was passed by a rig going 75 mph to 80 mph with only a couple of car lengths between the rig and vehicle in front of them. Am I overly cautious, or do a lot of folks pulling an RV trailer drive like an idiot? I don't see how they would ever stop if the need arose. I also noticed how they cut back into the lane in front of me with little space between the end of their rig and nose of my truck. Seems like not a good idea in a car - seems like a really bad idea towing a trailer. At least, how I see it.
Thanks much.
Brake controller
Thanks much.
