Well after all the fanfare and hoopla and not getting answers from the competitor, I had the opportunity to try out a PE EZ this weekend for the first tow with the ETH. I put on a little over 900 miles and ffom my perspective this unit has to be defective. I pulled the first 200 miles with out the EZ connected. Thought the stock ETH handled the 5ver quite well, especially as windy as it was. I topped off the tank and calculated the fuel mileage and came out just over 12 mpg. Not bad for only 5k on the truck. I then connected the EZ without the elbow. Could tell the difference as soon as I took off; but smoke (black) and EGT skyrocketed 1250 degrees pulling a moderate grade for WI and engine sounded rough running to me. Pulling from about 1600 rpm up to 2000 rpms the truck would buck with the 5ver on it. Fuel mileage dropped to 9 mpg. Same road conditions. My empty fuel mileage also dropped by alittle over 2 mpg. Decided that maybe EGT were causing some of problem, also disconnected and reconncted EZ connections and installed the elbow. Pulled 5ver back the first 200 miles. EGT's never over 850 degrees, boost would reach 30+ psi (only have 30 lb gauge), but truck would buck from about 1600 to about 2000 rpm in 6th gear. By buck I mean almost like a gasser with a carb out of adjustment, or an ignition miss. Never noticed in 1st thru 5th gear. Or when empty. Well to say the least at my next fuel stop I disconnect the EZ, put back stock elbow and came rest of the way home stock and the truck ran purrrfecto. Got home late tonight so I couldn't call out to Utah and I am in NYC the rest of the week.
The box is set in position 3 from Utah.
Connected and re-connected the electrical connections several times.
Any other suggestions?
"01" Forest Green QC/LB ETH/DEE,4x4, 3. 54LSD, VDO (boost, pyro) Westin SS Nerf Bars and Grill Gaurd, Delta tool box, K&N.
00 28' Jayco 5th Wheel, 86 "Classic 16" Alumacraft, 00 Honda Rancher
Towing with a slight "edge" on the competition!
