I don't intend in getting into a debate with you over what I expect a transmission to do, First the I don't run Mach6 or any injector like that, stock 160 injectors on a 95 and I don't have 1000lb lb of torque or what ever you have and I don't have egt problems or smoke.Originally posted by Snow man
Maybe im off base here,but the i thought 1750RPM minimum was for the transmission longevity. Since none of the aftermarket companys build there own planetarys for the OD unit, this would apply to all automatics. Just like your not supposed to pull hard with a 5 speed below 1600 in 5th,it doesnt matter whos clutch is in it. This driving style is abusive on trans hard parts,the rear,and the engine,more so than winding it up in the lower gear. As for slipping the TC ,I hit the nitrous on my truck from 1600 locked up,many times,both on the road and dyno and the torque instantly buries the 1200ft lb limit on the dynojet. I did that on the street,never any slippage,so i dont think the single lockup TC is a problem, my biggest concern would be the rest of the trans.
I have pulled hard at 1550 for a few seconds with Dads DTT modded 01,with the box on 3x3,and the DD2's,the little HY35 spooled right up,the truck pulled,nothing slipped, but you could hear and feel the driveline straining,it clearly wasnt happy. Why anyone you want to drive like that,and pull hard at that rpm ill never know. i have cruised at 1550 in lockup on the flats,it seems to do fine there,but any kind of hill/headwind and its not happy. Also most 24v trucks with aftermarket injectors will smoke at anything below 1600 under a good load.
The 5th gear problem is because of poor made splines? It very well could be because of torque rise and a resonate vibration at that rpm. I was told the 1750 was a oil pressure problem but I may have not heard correctly so who ever has the correct answer please answer. The difference between street and drag racing,dyno is ? THROTTLE ANGLE unless I am wrong and that could be wrong, at this point I can live with it
Sir I am sure you mean well, but every one does not run large injectors and big boxes or large turbos.
The simple reason is if I am driving along and the speed limit drops from 70 to 65 and I have a trailer in tow the rpm have dropped to ( 3. 54 gears and your are 4. 10) where I have to drop to 3 gear lockup . The biggest issue for me is egts. I have a Gage so I watch them. If they are a problem then I will down shift not because of a transmission. You may not under stand now but that is the reason.
If your transmission is so much better will your vendor give you a 100 k warranty and no time line line. jimk
