A highly modded HX35 will not even begin to suffice a 12 mm plunger VE on steroids with POD,s. Perhaps if the cylinder head is highly polished/ported in conjunction w/ many other air in/out mods... ... ... ... ... ..... ?
i can see what you are saying gl. i have not even been into the pump yet but with the afc maxed i can put more fuel into this thing that it can come close to using with just a few turns of the fuel screw
i take it use the fuel that even one of these ve's can supply you would have to inst studs and o-ring the head...
what should i set the max boost at for a stock motor???
