Don't you want to keep the littlest stage to benefit from compounding the air charge 3 times. I agree, spool up is not an issue with a competition puller.....
... . but boost is. Were talking air density here, not lag.
150 psi. Well, it is what it is.
If spool up is not a concern, you try to get away with the biggest small charger you can as to not heat the air any more then you have to. correct?
You still are taking a big straw and sizing it down to a little staw with more PSI to re-compress. You'll get more CFM outa a bigger "small" charger.
Am I on the right track here with the "big" set of twins vs a tripple set with a stocker on the hot side?
